regular sleeves or not???
Old Apr 22, 2004 | 02:16 PM
SHhh__VTEC's Avatar
Default regular sleeves or not???
My motor is running real bad right now and i'm gonna be pulling it out soon. I have oversized type s pistons in it BUT with standard size rings. My block was done wrong to install the type s pistons so that's why my engine is a mess. I'm burning a lot of oil and the engine sounds like a putt putt. LOTs of power lost.
I want to be able to continue using my type s pistons with oversized rings this time, but I'm gonna have to resleeve the motor. I'm not gonna be running high power or boosting or anything ( just another rebuild ). Are there any regular sleeves I can use or do I have to go with high dollar ones like darton, GE, ETC.... My friend told me to go to benson to get it resleeved but i can't find the website or number (or is there any). I dont want to spend too much money or high dollar sleeves b/c i'm not gonna be running too much power or boosting. Can anybody recommend some places I can go??
I tried searching but all I seen was resleeving for big power or boosting with high dollar stuff.
thanks
Old Apr 22, 2004 | 02:32 PM
Rick Solis's Avatar
Default Re: regular sleeves or not??? (SHhh__VTEC)
Heres a link to a LA Sleeve distributor
http://www.importperformanceparts.net/
Most machine shops will charge anywhere from 100-300 to install them.
Old Apr 22, 2004 | 03:40 PM
SHhh__VTEC's Avatar
darn it i'm not sure which one i need. 1/16, 3/32, or 1/8. Those LASCO sleeves will work good enough for the engine to run strong huh??
Old Apr 22, 2004 | 03:50 PM
Rick Solis's Avatar
Default Re: (SHhh__VTEC)
yeah, they are standard Iron sleeves. Good for a NA aplication, not too sure on how theyd do with FI.
Old Apr 22, 2004 | 04:03 PM
SKDRCR's Avatar
Benson does make good sleeves.
I'm not sure how much you'll be saving
compared darton or ge though....
Old Apr 22, 2004 | 04:09 PM
PrecisionH23a's Avatar
Default Re: regular sleeves or not??? (SKDRCR)
Benson has all of his sleeves custom made by Darton. Talk to 'earl' if you want more info on benson's.
Old Apr 22, 2004 | 04:30 PM
flylwsi's Avatar
sounds like you're staying NA, not sure why you'd run the type s pistons in an FI application...
i'd recommed getting a good set of rings for those pistons...
they're the same "bore" as stock,but higher compression...
so you don't need to change the sleeves, unless they're damaged...
are you sure it's the pistons/rings that's causing your oil burning?
Old Apr 22, 2004 | 05:13 PM
SuperSlow's Avatar
Default Re: regular sleeves or not??? (flylwsi)
Read his post again. oversize pistons, standard rings, and it is now running bad...
His cylinder walls probably look like shizzle.
Old Apr 22, 2004 | 07:01 PM
SHhh__VTEC's Avatar
nOOO no boosting. I searched and found sleeving for boost. I'm gonna have to resleeve for a basic rebuild. I'll find out how my motor looks like when i pull it. I'll start pulling it when I have time. My b-day is comin up in less than a week. So i'll be busy for a bit. and what sucks is that i'm carless for my b-day.
Where's benson?? or how can I get in contact to them? There's a shop down here that can resleeve each cylinder for 60 a hole but i'll have to supply the sleeves. OR they can sell my some iron sleeves for 100-150. something around there. What Should I do???
Old Apr 22, 2004 | 07:16 PM
SuperSlow's Avatar
If they sleeve hondas and other imports often, check them out. If they just do V8s and domestic ****, walk away and never go back.
Old Apr 22, 2004 | 09:19 PM
SHhh__VTEC's Avatar
yea, they're domestic people. So I shouldn't mess with them at all??
ohsnapzafingcu
Jun 20, 2012 10:49 AM
jyacoba2009
10
Oct 25, 2009 08:36 PM
slambedcivic
Aug 17, 2009 12:47 PM
HybridKOOP
Jun 29, 2007 11:11 AM
methos713
21
Jun 14, 2007 10:56 PM
