Engine Stalls??
Old Apr 19, 2004 | 12:46 PM
h22mark's Avatar
Default Engine Stalls??
Hey everyone, yesterday I was working on my car cosmetically, and had my car sitting in the garage for the whole weekend. Anyways I had 3 bars of gas left turned my car on to warm it up, sounded fine, then like 5-6 minutes later it stalled on itself, I have been having this problem for a while but never happened durning the warm up. Not sure I think its my timing, anyone have a clue? I have a JDM F22B DOHC. It happens when I also back out of my driveway, and my drive way has a steep incline. But usually I just give it a little gas to prevent it from bogging out. Any help would be great thanks.
Old Apr 19, 2004 | 12:58 PM
EFz6er's Avatar
Default Re: Engine Stalls?? (h22mark)
Whens the last time you changed the fuel filter??
Old Apr 19, 2004 | 01:30 PM
h22mark's Avatar
Default Re: Engine Stalls?? (puddz27)
Never did since I got the car about a year and a half ago. And not sure if the previous owners did, because many things that I replaced looked like the ORIGINAL factory part from when the car was made . But the engine sputters like the idle is fucked up, so I assume its the timing, anyothers want to chime in?
Old Apr 19, 2004 | 02:38 PM
blackdelslo's Avatar
Dirty air filter? I just cleaned mine with K&N filter cleaner, DAMN did alot of dirt come out.
Old Apr 19, 2004 | 04:02 PM
Speedra500's Avatar
check your fast idle valve
Old Apr 19, 2004 | 04:35 PM
h22mark's Avatar
Default Re: Engine Stalls?? (Speedra500)
Don't know where that is located, if you could post a pic or diagram that would be great thanks.
Old Apr 22, 2004 | 11:47 AM
vitegra
Guest
Posts: n/a
check for fuel leaks around injectors and any vacume leak could have a bad 02 sensor and when it goes into open loop idle the car gets too rich or lean and stalls out.
Old Apr 23, 2004 | 10:09 AM
h22mark's Avatar
Default Re: Engine Stalls?? (vitegra)
Thanks gonna check that out...
moacsupreme
Oct 19, 2014 02:15 PM
dayaftertomorrow33
Feb 11, 2009 08:24 PM
xEJFDMx
11
Nov 20, 2007 02:56 AM
alex_s817
Mar 6, 2007 05:38 PM
Kolijian
Jul 2, 2002 08:28 AM
