How to find out what year H22a4?
Is there a way to tell the year of an H22a4 block from just looking at it from the outside? All I can find are B/D series info. Never anything for the H guys!
The crankbolt on my H22a4 sheared off inside the crank and pretty much destroyed the keyway and surrounding area, so I'm shopping for a new crank/shortblock. Honestly, I don't know what year this A4 is when I bought it. Is there a way to tell from maybe the motor vin plate? Thanx for any info!
Re: How to find out what year H22a4? (Finest)
Last i checked all H22A4's were only on USDM TypeSH models which is 97-01.
The block is slightly different to fit the ATTS. oil filter is in a different position and so on. hope this helps
Re: How to find out what year H22a4? (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH »</TD></TR><TR><TD CLASS="quote">Last i checked all H22A4's were only on USDM TypeSH models which is 97-01.</TD></TR></TABLE>
Hmm, are you sure?...I do know that all 5th gen Ludes came with an H22a4. (And not just the SH models either) But I'm trying to find out what specific year my motor came from. The reason I ask is because there was a significant design change from the 98+ H22a4's, with the larger main journals. I just need to know which year my H22a4 came from before I search for a new crank.
im not 100% positive on that, just pretty sure
i think i saw on someones post where they broke it down, ill go double check.
H22A1 2.2L USDM DOHC VTEC 92-96 Prelude VTEC 190hp
H22A4 2.2L DOHC VTEC 97-01 Prelude VTEC/SH 97-98: 195hp 99-01: 200hp
H22A 2.2L JDM DOHC VTEC 92+ Prelude Type-S, 97+ Prelude SiRS Spec 220ps
H23A1 2.3L USDM DOHC non-VTEC Prelude Si 160hp
its in essential prelude links. specs n what not.
all the dates of the motor is stamped on the block and many many places it looks like a little thumbsize circle by the header is one and it reads the month and year the motor was made.
The only difference that is important relates to the Base versus SH. The location of the oil filter is different-on the end of the block (SH) rather than centered (BASE). As to what year- it really makes little difference at all since Honda played with the HP number. The camshafts are unchanged as far as I know. Also-you said you want only a shortblock so the head will be the one you now have. ALL h22a4 engines are otherwise identical for the USDM version.
Re: How to find out what year H22a4? (jc836)
If I can find a replacement crank, that'll save me a ton instead of having to purchase a whole short block.
So for that reason, I need to know what year my H22a4 is before I go looking for a replacement crank.
I'll check out afterburner's suggestion.
I have been told by various people that the 97 crank is different than the 98 and up. Also, in 97 they used floating wrist pins.
My motor is currently apart and I would be more than happy to give you any specs you need off of it when I get it back next week.
Re: How to find out what year H22a4? (yellow_jacket)
To tell what year your motor is, if it's complete, there are some small circles right above the header. They always have a 9 and then a veritcal line and then the next number. Let say it says 9 | 8 this means your motor was made in 98' but used on a 99 prelude.
Re: How to find out what year H22a4? (caLiH22A)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by caLiH22A »</TD></TR><TR><TD CLASS="quote">To tell what year your motor is, if it's complete, there are some small circles right above the header. They always have a 9 and then a veritcal line and then the next number. Let say it says 9 | 8 this means your motor was made in 98' but used on a 99 prelude.</TD></TR></TABLE>
Thanx, that's exactly what I needed.
It says 9 | 6. But then again, it does look like an 8. Argh! I'm just gonna tear this thing down!
Here are the stats that you are looking for
1997 engine numbers
engine type H22A4
serial number: Prelude 1000001-
serial number: type SH 1500001-
1998 engine numbers
engine type H22A4
serial number: Prelude 2000001-
serial number: type SH 2500001-
1999 engine numbers
engine type H22A4
serial number: Prelude 3000001-
serial number: type SH 3500001-
2001 engine numbers
engine type H22A4
serial number: Prelude 500000-1
serial number: type SH 5500001-
I don't see anything about the year 2000 prelude stats because my helms is a 97-99 with the 2001 supplement
Good luck with the search for a new crank
1997 engine numbers
engine type H22A4
1998 engine numbers
engine type H22A4
1999 engine numbers
engine type H22A4
2001 engine numbers
engine type H22A4
Re: How to find out what year H22a4? (RoAdK1LL)
It would only make logical sense that the 2000 is:
engine type H22A4
serial number: Prelude 4000001-
serial number: type SH 4500001-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoAdK1LL »</TD></TR><TR><TD CLASS="quote">Here are the stats that you are looking for
1997 engine numbers
engine type H22A4
1998 engine numbers
engine type H22A4
1999 engine numbers
engine type H22A4
2001 engine numbers
engine type H22A4
engine type H22A4
1997 engine numbers
engine type H22A4
1998 engine numbers
engine type H22A4
1999 engine numbers
engine type H22A4
2001 engine numbers
engine type H22A4
1998 engine numbers
engine type H22A4
You are a saint! I owe you one bro.
I guess it's a 98 afterall. The serial number stamped under the H22a4 is 2007724! Time to go shopping for a bottom end rebuild!
1998 engine numbers
engine type H22A4
Where can I find a block? I have a 1999 sh. I blew the block. Its cracked and I can't find it anywhere?
what models will fit? It does have the atts transmission.
If you buy one with transmission you have lots of options.
But if you want to keep your current transmission with ATTS you need (97-01) SH block/engine or JDM Type S
djsire
09-21-2006 09:40 AM
Bigjussin
07-23-2005 01:00 PM
