what does this part do?
Old Apr 19, 2004 | 04:45 PM
monalisa overdrive's Avatar
Default what does this part do?
part #5 i think, or six (the plastic housing inside the cap of the distributor behind the rotor)
i accidentally broke it and ended up taking it off...do i need it or am i okay to just leave it out?
part should be right underneath------------------------------------------here
Old Apr 19, 2004 | 08:00 PM
stupidfox's Avatar
Default Re: what does this part do? (monalisa overdrive)
it looks like all it would really do is keep wires and such away from the rotor so you might be ok without it... but as a rule of thumb honda pry would put it there just for the hell of it... hopefully one of the electrical nuts will jump on this one otherwise i'd say pony up a couple bucks and order one. good luck!
Old Apr 19, 2004 | 09:07 PM
skrewdlude's Avatar
I have no idea if it is ok or not, but I have run with out it for a long time. I am sure it is to keep the rotor/cap/current from coming into contact with the wires in the distributor. The air inside the distributor cap can become charged, so this probably helps sheild the wires, and sensors in the distributor from damage..
-Josh
yangkm
Feb 26, 2011 04:20 PM
93CivicDxer
May 23, 2005 07:16 AM
Japanese1.6
Apr 10, 2005 08:42 AM
Casey
Jul 28, 2003 02:15 PM
FastNFurious
Jun 19, 2003 09:14 PM
