3rd gear problem
Old May 8, 2004 | 07:47 PM
Prelude83's Avatar
Default 3rd gear problem
for some reason when i'm driving when i switch to 3rd gear it grinds but it doesnt do it all the time just when i'm driving real fast and sometimes even when i'm just cruising yo somebody let me know wht up
Old May 8, 2004 | 08:39 PM
SpyLude92's Avatar
Default Re: 3rd gear problem (Prelude83)
Sounds like you have a worn syncronizer. I have heard of people trying GM Syncromesh fluid, and some other types of fluid to smooth out the problem. Replacing the worn parts is really the only way to solve the problem.
Old May 8, 2004 | 09:02 PM
Prelude83's Avatar
Default Re: 3rd gear problem (SpyLude92)
oh aight i had changed the slave but it minimized it but my boy waz like i could be switching gears to early or some ****
Old May 8, 2004 | 09:34 PM
98TypeSH's Avatar
do you refer to all your friends as "my boy" ? sounds jolly good my boy. shifting to early would not produce a noise. riding the clutch, not using the clutch, missshifting, would cause a nice grind. otherwise its as said before. is it like a fat *** grind and its throwing it out of gear, or just a little click ?
Old May 11, 2004 | 06:50 PM
Prelude83's Avatar
Default Re: 3rd gear problem (98TypeSH)
yea sorry it's a black thing but i appreciate ur replys
Old May 11, 2004 | 07:53 PM
C M S's Avatar
I had the same prob in my H22, but in 3rd and 5th. I put in GM synchromesh FM(I have LSD) and ALL the grinds are gone now. The only way to fix the prob is with new parts, but GM Syn will get by ....
Old May 11, 2004 | 09:03 PM
spanishgt99
Guest
Posts: n/a
Default Re: 3rd gear problem (1SICJDM)
3rd gear syncro usally goes out first in our trannys! Put GM syncro mesh and start saving!
Old May 13, 2004 | 10:18 PM
Prelude83's Avatar
Default Re: 3rd gear problem (spanishgt99)
true but i'm about to drop a 2000 motor and tranny in thr so i'm good
Type_Rb18c5r
Mar 12, 2008 03:43 PM
Villenurve
Oct 12, 2007 09:58 AM
dynamyks
Jun 23, 2005 09:10 PM
4DRmafia
Jul 8, 2004 08:36 PM
vtek4life
Mar 24, 2004 03:37 PM
