Remote start?
Old May 12, 2004 | 02:32 AM
Longitud's Avatar
Default Remote start?
Is there somebody here that's got a remote start on his gen5 lude? (manual)
I have a remote that can start the car and wanted to do that. I have problems getting past the Immobilizer unit.
If somebody here has it, how did you connect it?
PS. Those who plan on talking about the risks on this don't bother on posting. I know the risks and just want to know how to plug it in. DS.
Old May 12, 2004 | 07:03 AM
Thirty-Nine's Avatar
Default Re: Remote start? (Longitud)
I thought you could only have remote start on automatics due to the fact you have to push the clutch down to start a manual trans ...
Old May 12, 2004 | 07:31 AM
94Vtecluder's Avatar
Default Re: Remote start? (Sushiboy)
Umm, I don't have to push the clutch down to start my car.
Old May 12, 2004 | 07:34 AM
93ludeSi's Avatar
Default Re: Remote start? (94Vtecluder)
yea, you can disable the cluch safety switch, not sure on the imobalizer
Old May 12, 2004 | 08:02 AM
slverstreak's Avatar
I have a remotestart/alams installed by my self. You need to get an imobilizer bypass (15 $ US). Check out the Peripheral web site. It has the wiring diagram for the (TBHA1) transponder interface. I installed another make, bu the wiring is all the same. You need this to sumlate having a key in the ignition so the car will strat remotely. Hope this helps.
Old May 12, 2004 | 05:14 PM
rjr162's Avatar
Default Re: Remote start? (Spoolfool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spoolfool &raquo;</TD></TR><TR><TD CLASS="quote">DEI makes a key immobilizer bypass. With this you don't have to use a spare key in your car... you just program it. </TD></TR></TABLE>
yeap, same thing I did except I used one by a company from canada. DEI makes the 555U which is a universal and requires no wiring into the car (the only wires you need to tag are ones on the remote start unit its self), and then they also make one you can wire into the immob system and it remembers the code from the key so you don't need the "key in the box" like the 555U requires
Old May 13, 2004 | 06:23 AM
Longitud's Avatar
Default Re: Remote start? (slverstreak)
So there isn't a way to get past the immobilizer, manually?
have to by a bypass kit?
EF_Nina
Sep 30, 2011 02:15 AM
nocturnal EG
Audio / Security / Video
May 20, 2006 04:24 PM
cruzin89lude
12
Feb 15, 2006 08:21 AM
s13_240sx_92
Jan 31, 2005 06:48 AM
patastinky
Apr 25, 2004 02:06 PM
