Piston question
Old May 6, 2004 | 05:28 AM
musclefella's Avatar
Default Piston question
I know i've searched, but things aren't clear for me.
Prelude Si H23a3 t3/t4 FMU,DSM,SAFc, Walbro blablabla
I want more power, but have to build my H23a3. Only problem is in my country we don't sleeve. So i want to run forged pistons and rods on the stock sleeves.In my country are no tuners that sleeve.How much psi can the stock sleeves take.
I know there's a difference in materials, so not every combo will work. What combo does work.
Do i have to coat them?? Which ones will fit?? From what i've read, wiseco with skirt design will fit. What rods would be best??
I want to run 12 psi maybe 15 psi ones in a while, what can i do without sleeving??
In my country i need to order everything from america, so i really need to order the right stuff.
Greetz
Old May 6, 2004 | 05:45 AM
SKDRCR's Avatar
Default Re: Piston question (musclefella)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by musclefella &raquo;</TD></TR><TR><TD CLASS="quote">I know i've searched, but things aren't clear for me.
Greetz</TD></TR></TABLE>
ditch the fmu, ditch the safc
if you're gonna risk it running forged internals with stock sleeves,
you're gonna want a better engine management system,
EXPECIALLY if you wanna run 12-15 psi
Old May 6, 2004 | 07:00 AM
Default Re: Piston question (SKDRCR)
That's the best i can do for now, i'm a student and bodybuilder and don;t have the funds for that right now, but i will soon. With the FMU and Safc i can still boost 12 psi and have a little bit of management. I also have MSD 6 al, MSD BTM, Blaster ss coil, MAgnecor 8.5. So i should come a long way right? I just want to bulletproof the engine for more boost later on in the project.
This is what i have right now, what's the best i can do with this setup?
I'm talkin forged pistons stock sleeves here.
Advice please no lectures about anything else
Old May 7, 2004 | 06:26 AM
anyone?
Old May 7, 2004 | 06:28 AM
see_our_vtec's Avatar
good luck? lol
Old May 7, 2004 | 10:46 AM
94Vtecluder's Avatar
Default Re: Piston question (see_our_vtec)
If you can't sleeve deep freezing it. It's supposed to extend life 150-500%. I've yet to hear if anyone has tried it yet but I've heard a lot about it. It's real cheap and could possibly be a cheap way to get a high boosted turbo and get around sleeving it.
http://www.deepfreezecryo.com
Old May 7, 2004 | 11:37 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by musclefella &raquo;</TD></TR><TR><TD CLASS="quote">That's the best i can do for now, i'm a student and bodybuilder and don;t have the funds for that right now, but i will soon. With the FMU and Safc i can still boost 12 psi and have a little bit of management. I also have MSD 6 al, MSD BTM, Blaster ss coil, MAgnecor 8.5. So i should come a long way right? I just want to bulletproof the engine for more boost later on in the project.
Advice please no lectures about anything else</TD></TR></TABLE>
Here's some advice then, if you're gonna use a shitty ems,
and you want it to last, dont boost over 6-7 psi or it's gonna cost
you bigtime
Old May 7, 2004 | 03:22 PM
satan_srv's Avatar
you can't run forged pistons in stock sleeves.
you can't reliably boost over 6-7 psi without excellent tuning and fuel management
end of story. Since you can't sleeve and don't want to get a full standalone you might as well stick to bodybuilding instead of engine building.
Old May 8, 2004 | 08:11 AM
Default Re: Piston question (94Vtecluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">If you can't sleeve deep freezing it. It's supposed to extend life 150-500%. I've yet to hear if anyone has tried it yet but I've heard a lot about it. It's real cheap and could possibly be a cheap way to get a high boosted turbo and get around sleeving it.
http://www.deepfreezecryo.com</TD></TR></TABLE>
Looks like an option to me, i'll try to find out if any tuner over here does this, and see what the possibilities are. Thnks for the advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">
you bigtime </TD></TR></TABLE>
Okay cool, i'll try to stay within limits then, for a while I've been running 9 psi for 3 months now, still no ringland problems or any problems, I want to get rid of that scary feeling that things are gonna break when really stepping on it. Just so you know, there isn't even a hondata dealer over here, that's how crappy stuff is over here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">you can't run forged pistons in stock sleeves.
end of story. Since you can't sleeve and don't want to get a full standalone you might as well stick to bodybuilding instead of engine building.</TD></TR></TABLE>
There's a guy on the board(dc98l something)running forged pistons on stock sleeves turbocharged for 25k miles now. So i wouldn't say can't. I have enough fuel management for 7 or even more psi right now. The story doesn't end for a long time, there are still options and i'm still trying to find out the best thing to do. I can't sleeve "over here'' Who said i don't want to get a standalone. i already have one, but it may not be known to you(it's a stinger stand alone) Not installing yet looking for a good base map. Engine building and bodybuilding go great together i can lift the block my self.......always handy. So i'll build two ways if you don't mind.
Old May 8, 2004 | 09:36 AM
2kflamedlude's Avatar
Hey the only alternative is that I would order new OEM pistons and send it out and get it cryo treated. Its about 70 dollars to get your pistons treated. http://www.percryo.com/ Shoot those guys an email they helped me out alot with my tranny work.
Old May 8, 2004 | 09:37 AM
Default Re: Piston question (2kflamedlude)
Okay cryo treated is possible here, but there still be that ringland problem right?
Old May 8, 2004 | 09:40 AM
Im sure there still might be. Think of it this way.. You will have stronger pistons and connecting rods and less chance of blowing it up. If you get this done and proper tuning I think you will be ok. This is better alternative I see on closed deck design.
Old May 8, 2004 | 10:02 AM
I have a h23a3 haven't opened her up yet, but i'm geussing it's closed deck(hoping). I'm gunna start making some calls next week. Thicker head gasket and Cryo treatment are now running trough my mind. Maybe install the Stinger standalone next week to and go to the Dyno and see what happens.
I've already emailed Wiseco to ask if they have an option for the forged pistons on stock sleeves idea.
Thanks for advice man i appreciate it
Any more tips are always welcome.
Old May 10, 2004 | 11:35 PM
E mailed Wiseco last week, and got some response. I asked them about the Wiseco forged pistons on stock sleeves in a H23 block. and this is what they told me
The use of stock sleeves are no problem, nikasil coated or oncoated no problem, the ringlands are made for this. only problem is when sleeves are chroom plated, but this is very oldschool. (That's ruffly translated what he they said)
In their catalog they have pistons for the h22 and not the h23 he gonna let me know the part number so i can order.
Couple of questions, how much psi can i run with the wiseco pistons and stock sleeves with good management etc etc?? What rods go best with these pistons??
Do these rods come with new rod bearings??
Modified by musclefella at 10:27 AM 5/11/2004
DrivinVtec
Aug 1, 2006 03:53 PM
Got_EF8
13
Feb 17, 2006 08:02 AM
OrangeBoost
Sep 26, 2005 10:46 AM
Vega
Dec 12, 2003 08:45 PM
ID_ten_T
Jul 17, 2003 02:43 PM
