Not Understanding ABS Codes
Old May 23, 2011 | 10:45 AM
InvaderTrax's Avatar
Default Not Understanding ABS Codes
My ABS light came on for the first time. I jumped the connector and got one pulse, pause, three pulses, pause, four pulses with a short pause then eight pulses. Does that mean the first one is pump over-run, and the last one is LR speed sensor? No idea what a stand alone three is, unless it's actually 1-3: high pressure leak. I'll probably clear it and see what comes back. I have noticed in the past year the pump primes more often, and takes longer to prime than it used to
Old May 23, 2011 | 11:00 AM
1GPlusSH's Avatar
Default Re: Not Understanding ABS Codes
you have long pulses and short pulses. long pulses are 10s, short pulses 1s. each code is separated by pauses. so, in your case, if the one pulse was a long pulse, that code is 13 if there wasn't a long pause and the next three pulses were short. if the four pulses were long pulses, you have 48 if there wasn't a long pause and the next eitht pulses were short. if all pulses were long, you have 10, 30, 40, 80. if all were short, you have 1, 3, 4, 8.
I hope that was thorough enough.
Old May 23, 2011 | 11:24 AM
That's for engine codes. ABS codes are seperated into main and sub system codes with all pulses at the same speed (see Helms 19-55)
Old May 24, 2011 | 03:34 AM
1GPlusSH's Avatar
i'm probably wrong, but i remember pulling ABS codes. i am almost certain they were exactly like engine codes with the pulses.
If I'm wrong, sorry abou the misinformation.
Totes Magotes
Jun 28, 2013 09:01 PM
racer4
Dec 11, 2010 08:09 AM
cityslicker1606
Aug 31, 2007 04:29 AM
JOHN07
Acura TL, RL & ZDX
Aug 6, 2005 12:46 PM
oryanh
Dec 15, 2003 06:46 PM
