cooling system/temp sensor help...
Old Jun 16, 2011 | 07:41 PM
k20tegftw's Avatar
Default cooling system/temp sensor help...
i recently purchased a 92 prelude s, 2.2 5 speed etc. i have a problem with fans not turning on, unless the a/c is on. my friend said its probably a temp sensor. there is one near the thermostat housing and one on a piece on the front of the block. what would these be called if i should replace them? what else could it be? or which one, (if this would be a better option) would be the one to wire up a manual fan switch. any help is greatly appreciated, im stumped...havent dealt much with cooling systems. thanks.
Old Jun 18, 2011 | 08:06 AM
k20tegftw's Avatar
Default Re: cooling system/temp sensor help...
anyone? ive already done the obvious and replaced the thermostat and that did nothing...i cant figure this out.
Old Jun 18, 2011 | 08:08 AM
Enzo15's Avatar
Look up a wiring diagram to see which one controls the fans and test that one to see if its working properly. Dont just buy parts without testing to see which one might be bad.
Old Jun 18, 2011 | 08:35 PM
k20tegftw's Avatar
fair enough...ill see what i can find
Old Jun 19, 2011 | 02:12 PM
SouthTexasRich's Avatar
k20, out of curiosity, is the car also hard to start in the morning or in cold weather?
I had a temp sensor problem and that was how it manifested itself. It didn't overheat, but the hard starting was my symptom.
Old Jun 19, 2011 | 02:42 PM
nus_dogg's Avatar
Yes, if the ECT is bad, it'll show -40 which is what the ECU will see. The ECU thens tells the injector to dump in hella fuel in causing it to hard start because you need rich mixture to start a cold engine due to poor fuel atomization. So it takes a bit to start up.
Old Jun 19, 2011 | 10:15 PM
flyrod's Avatar
sounds like the sensor on the head. Not the one with a single wire, that goes to the gage on the dash.
Old Jun 20, 2011 | 04:56 AM
5SpdH22's Avatar
something gnarly
Active Streak: 30 Days
Thermostat housing one will work if you wanted to make a manual switch.
Is your car overheating though? My fan pretty much never goes on, but my car never overheats either (aftermarket gauge, the stock one blows). I get the correct resistance reading from the fan switch and the fan definitely works.
Old Jun 20, 2011 | 09:52 AM
mextera's Avatar
what is the trick to start when this is the case? mine just started doing this I need to get it to where I can work on it.
Old Jun 20, 2011 | 08:23 PM
k20tegftw's Avatar
yeah its over heating...small bubbles in coolant...noticed them today so im 99% its headgasket
Wyatt Carter
Jun 5, 2017 09:50 PM
nogodracer23
Nov 20, 2013 12:10 PM
Bb16ahatch
Mar 9, 2007 03:40 PM
ek4d00r
Aug 1, 2005 04:12 PM
yellowturbo
Jan 7, 2004 02:44 PM
