Obd2-obd1 conversion question
Old Jun 15, 2011 | 12:58 AM
fastrider213's Avatar
Default Obd2-obd1 conversion question
I have a 96 obd2 h22 lude the ? I'm asking is if I get a obd2-obd1 jumper harness with a chipped p28 will I need to switch my dizzy with and obd1 H22 dizzy or will the jumper harness eliminate that problem?
Old Jun 15, 2011 | 06:22 AM
1GPlusSH's Avatar
Default Re: Obd2-obd1 conversion question
i was going to post the link here for you, but it's broken. maybe someone knows the specifics...
i believe you still have to switch the dizzy because of the crank position sensor.
Old Jun 15, 2011 | 10:25 AM
People are saying that I will need to change my Fuel injectors... injector clips... resistor box... dizzy ..... ecu...
Old Jun 15, 2011 | 11:12 AM
1GPlusSH's Avatar
yes...do some research on the swap. i assumed you had all of that taken care of.
Old Jun 15, 2011 | 10:05 PM
I've been doing research but no one seems to give me a straight answer
Old Jun 16, 2011 | 04:03 AM
1GPlusSH's Avatar
research doesn't mean asking people questions.
Old Jun 16, 2011 | 05:21 AM
jkoni426's Avatar
You sure you can even do that in cali? They're the strictest state on emmissions...
Old Jun 16, 2011 | 10:18 AM
Finally got the answer which is to go p72 instead of p28 ecu woot!
Old Jun 16, 2011 | 03:19 PM
1GPlusSH's Avatar
is that the right answer? so the p72 will solve all your issues?
1native
Dec 29, 2013 07:23 PM
1Point8DC2
Oct 1, 2007 03:27 AM
anth2k4
Feb 26, 2007 02:12 PM
Flava
13
Aug 2, 2006 02:38 PM
prelude9999
Sep 29, 2004 09:07 AM
