97 prelude- head problem
Old May 21, 2011 | 09:06 PM
Griffo's Avatar
Icon6 97 prelude- head problem
I have a 97 prelude which i took in to a shop to have the head repaired after the timing belt disintegrated on me. The mechanic said it needed 2 valves replaced so he sent it to the machine shop. I picked up the car 3 weeks ago and sounds awful as if the valves and the lifters were all loose so i took it back and the mechanic told me the car was fine and the noise was all due to the nature of the repair. I paid 2 grand- what should i do?
Old May 21, 2011 | 11:17 PM
AnicDC2's Avatar
Default Re: 97 prelude- head problem
I have a resurfaced 97 H22A4 head with new valves, valve stem seals, valve springs, retainers and comes with cams. 0 miles on head since rebuild. Cams and head had 70k before everything was done. Also have a head gasket kit for 350.00+shipping.
Old May 22, 2011 | 08:58 AM
minilogoguy18's Avatar
The machine shop wont set the valve lash, check it. Next time change your timing belt when you are supposed to, they usually last longer than the time that Honda gives for them.
Old May 23, 2011 | 04:23 AM
1GPlusSH's Avatar
only 2 valves? i thought that you either lose them all or none...depending on if you are in VTEC or not.
dude sounds pretty shady
Old May 23, 2011 | 10:07 AM
Luded93's Avatar
I would say valve lash or he left a bent valve or two still in. I had the same issues with a 90 prelude and came to find out that the guy replaced about 10 valves and left one in that had a little bend to it. Sounded like the car never had oil.
stockF22B1
Dec 15, 2012 07:08 PM
aznwash3wboi
Apr 21, 2009 12:58 AM
95ludeSE_bottle
Mar 23, 2008 11:15 AM
sasa97
Aug 3, 2007 03:43 AM
RedNeckHondaMan
Oct 8, 2005 09:25 AM
