No flexpipe?
Old Jun 27, 2004 | 03:56 PM
fireslinge's Avatar
Default No flexpipe?
Both SMSP and prospeed headers dont have a flexpipe on them as what i have seen from the pictures that have been posted. Dosent this greatly reduce the life of the header and make it more prone to cracking?
Old Jun 28, 2004 | 01:52 PM
fireslinge's Avatar
Default Re: No flexpipe? (fireslinge)
i think i already know the answer i just want confirmation...
Old Jun 28, 2004 | 02:08 PM
98TypeSH's Avatar
honestly i think you will be OK as long as you dont bottom out right on the friggin header or a nice curb speedbump.
Old Jun 28, 2004 | 02:09 PM
LudeyKrus's Avatar
From my understanding, they are important. I wouldn't want to go w/o one, as it absorbs the movements/vibrations from the motor.
Old Jun 28, 2004 | 02:21 PM
junbb1's Avatar
Default Re: (LudeyKrus)
i know the prospeed header uses a slip fit that you are not supposed to weld. this will give you the freeplay you need. and if you are still concerned then use a doughnut gasket with spring bolts to connect the header with the exhaust just like on the civics and integras.
Old Jun 28, 2004 | 03:39 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">honestly i think you will be OK as long as you dont bottom out right on the friggin header or a nice curb speedbump.</TD></TR></TABLE>
i have been lucky and bottomed out a couple of times REALLY badly and am still ok. but i will be going to Kteller.com and getting a flexpipe to weld on when i get back home.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">i know the prospeed header uses a slip fit that you are not supposed to weld. </TD></TR></TABLE>
actually brian told me to spot weld it...
Old Jun 28, 2004 | 03:51 PM
Behan's Avatar
Default Re: (Shakes)
the smsp header uses the same set up as an civic or integra ( floating flange, donut gasket, spring bolts). i haven't had any problems in a year and i even had a nasty encounter with a speed bump when i was lowered.
Old Jun 28, 2004 | 03:57 PM
fireslinge's Avatar
Thanks now i feel alot better about spending the money on one!
Old Jun 28, 2004 | 04:02 PM
Shakes's Avatar
space cadet
Default Re: (fireslinge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireslinge &raquo;</TD></TR><TR><TD CLASS="quote">Thanks now i feel alot better about spending the money on one!</TD></TR></TABLE>
honestly, if you are going to spend the 1300 on an SMSP you might as well spend the extra $45 and get a flex pipe. just ask dave when you order it if he will put one on to set your mind a little more at ease.
Old Jun 28, 2004 | 04:30 PM
Behan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">
In the following picture you should be able to make out the graphite donut on the collector. This is what is used for all other hondas/acuras. While the flex tubes provide more "flex" they don't provide the same flow quality so I really don't want to use it, plus it would probably add some cost to the piece.
https://honda-tech.com/zero...age=3
Old Jun 28, 2004 | 04:39 PM
TimeRacer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">honestly, if you are going to spend the 1300 on an SMSP you might as well spend the extra $45 and get a flex pipe. just ask dave when you order it if he will put one on to set your mind a little more at ease.</TD></TR></TABLE>
Dave doesn't like using flex pipes as they don't have the flow charachteristics as a slip joint. That's why he doesn't use them.
E.Honda
Jun 20, 2010 09:59 AM
kaj
Jan 11, 2008 03:29 PM
allmotorcrx2001
Dec 31, 2006 10:35 AM
coolgsrguy
Mar 26, 2006 12:17 AM
civic91
Sep 9, 2003 02:00 PM
