Need help wiring techmeter???
Old Jun 23, 2004 | 03:24 PM
mdj_ge's Avatar
Default Need help wiring techmeter???
Who in here knows how to wire the techmeter (RPM) on to the distributor… I have a 2000 prelude DOHC VTEC… please help…
I have a JDM Motor… and it’s an internal coil… There’s only one plug to the distributor because it’s a obd2 … anyone know how to wire it to the JDM Distributor…
Modified by yangja at 1:53 AM 6/24/2004
Old Jun 23, 2004 | 03:50 PM
gen4vteclude's Avatar
Default Re: Need help wiring techmeter??? (yangja)
The only connection you have to make to the engine harness is to wire the tach signal wire(probably green) from the tach(assuming aftermarket)to the coil negative,on my 4th gen, the coil negative is blue, I think the wire is the same color on your car, but i'm not sure
Old Jun 23, 2004 | 04:00 PM
hOndafienD 04's Avatar
you need a switched power (ignition, or something liek that) ground, and the other wire goes to either blue or green wire...on the 4th gen its blue...not sure bout 5th
Old Jun 23, 2004 | 04:54 PM
mdj_ge's Avatar
any more help??? anything is appreciated...
Old Jun 23, 2004 | 05:08 PM
Nikoli's Avatar
its tachOmeter
91CivicHatchback
May 22, 2005 03:45 PM
nonvtec
Apr 5, 2005 11:11 AM
mdj_ge
Jun 25, 2004 10:32 PM
tylek17
Jan 7, 2004 08:21 PM
H23vtecEG
Oct 14, 2003 05:02 PM
