Different radiator?
Old May 12, 2012 | 08:17 PM
AllMotorLudeSi's Avatar
Default Different radiator?
Shouldn't I be able to put a DA Integra radiator inside my '91 Prelude Si, so its not taking up too much space? and the fact that the motor likes to eat through the radiators i buy for the car or at least a civic radiator?
Old May 13, 2012 | 01:17 PM
LatnKng's Avatar
Default Re: Different radiator?
Have you measured the spacing of the radiator itself and the brackets just to be sure?? I personally don't know of anyone that has done a radiator swap from a Da to a BB2..or if it'll even line up.
Old May 14, 2012 | 10:11 AM
Im guessing that I need to do that first before even thinking about just ripping the cracked radiator out. I mean ive had people tell me I could do that easily but i dont trust what they say. But the one that told me I was able to do it drives a DA integra and he said I should be able to use that small radiator for it, but i dont know. Maybe I need a high performance radiator?
Old May 14, 2012 | 09:40 PM
TheJGB3's Avatar
I have seen a lot of Preludes running a Civic radiator. They went with one after deleting A/C, and going boost (for extra clearance for the turbine, down pipe, and intercooler piping).
Old May 15, 2012 | 06:17 AM
Now if I "do" decide to run a civic radiator with mine, would i have to get rid of the a/c?
Old May 15, 2012 | 07:25 AM
Wing8806's Avatar
Shouldn't have even touch your AC if you're just installing a different/smaller radiator. You will have to change how the radiator will be mounted though. (if you go civic half rad)
Old May 15, 2012 | 09:33 AM
Okay, thanks. Sounds like an easy thing to do.
Old May 15, 2012 | 11:30 AM
minilogoguy18's Avatar
From the way you're describing it sounds like the motor is torquing so much that it's punching a hole in the radiator, why not just fix the motor mounts that is the root of the problem?
Old May 16, 2012 | 04:27 AM
LatnKng's Avatar
I think he said that the current radiator was leaking and he was looking for any other that he could use for his BB from another chasis, preferrably a half radiator...again, I THINK.
Old May 16, 2012 | 04:30 AM
LatnKng's Avatar
You shouldnt have to touch the ac if your just replacing radiator..I dont have AC myself in my BB but i have WINDOW AC, which works wonderfully..and YES YOU SHOULD HAVE MEASURED EVERYTHING FIRST IF YOU ARE TRYING TO fit something in your car that might have worked on another chasis...ALWAYS RESEARCH..which im sure you did right??!!
Old May 16, 2012 | 08:20 AM
Wing8806's Avatar
Something I feel I should add though - although you won't need to touch your a/c, you will have to re-mount both fans somehow.
But since you're thinking about a radiator that's not stock, i'm assuming you've already taken that into consideration.
If you've not, Mizu makes decent aftermarket fans. Or you could figure a way to re-mount the factory fans.
Old May 17, 2012 | 06:07 AM
^^Im thinking about aftermarket. Ive had the car 4 months and its about time to tear the damn thing apart and get all new parts for it.
Old May 17, 2012 | 06:10 AM
typemismatch's Avatar
Honda owns me
FullBlown dual cores are nice and they are only $150 for the EG halfie
Old May 17, 2012 | 06:12 AM
Honda owns me
Also, I've got a stock EG rad and fan I'd be willing to part with. The stock EG fan mounts to the FB radiator, if you have the space for it.
Tacoma Luda
Aug 14, 2005 05:51 AM
tolowhb
Jul 9, 2003 02:22 PM
AVATAR
Jul 7, 2003 03:08 PM
