Rod Bearing Differences (Oil Hole) H22A1/A4, H23, F22 etc Help!
Old 04-28-2012, 09:17 AM
ESP.net's Avatar
Default Rod Bearing Differences (Oil Hole) H22A1/A4, H23, F22 etc Help!
Hey guys there is one engine that doesnt have the oil hole in the rod bearing which is it?
Ordering new acl bearings for my H23V and Crower has no oil hole in the H23 Rods, rather get bearings without hole...
H23/F22?
H22A1?
H22A4?
From what I remember the hole is for non vtec motors H23/F22 which don't have oil squirters?
Old 05-07-2012, 05:18 AM
Talon9871's Avatar
Default Re: Rod Bearing Differences (Oil Hole) H22A1/A4, H23, F22 etc Help!
I just got new rod bearings from ACL for the F23, and they came with no oil holes... I believe it's the same part as for the H23 and F22. I hunt down the part number if you want confirmation.
Old 05-07-2012, 07:57 PM
ESP.net's Avatar
F23 (B Series) are not as wide as H22 rod bearings
Old 05-14-2012, 07:20 AM
Talon9871's Avatar
F23 = B series, what? Anyway, the ACL part number for F22, H22, and H23 is 4B1936, but those rod bearings do have the oil holes in them. I couldn't find anything from ACL for those engines that don't have the oil holes, sorry.
Old 05-14-2012, 10:07 AM
ESP.net's Avatar
F23 have a b series width not same as h22/f22/h23
Yea I think ACL switched recently to putting holes in all... even though i have in the garage 4B1936A non race. Reason I am asking is cause I would think without the oil hole would be stronger then especially having a rod with no oil hole in it.
Old 05-14-2012, 05:13 PM
gstrudler's Avatar
I don't think you have to worry about bearing strength so much (especially in the middle); they either burn and/or spin when they fail.
Old 08-17-2012, 09:13 PM
niatsi's Avatar
I have a question it is a bit off topic so i want to bump up the compression ratio of mine h23a vtec i have seen a set it is this one:
NIPPON RACING PRELUDE TYPE S PISTONS in 87mm 87.5mm 87.75mm and 88mm
EAGLE FORGED 5394 H-BEAM CONNECTING RODS WITH ARP 2000 BOLTS
NPR GAS NITRITE N-51 TREATED PERFORMANCE RINGS.
9310 CASE HARDENED WRIST PINS WITH UPGRADED CLIPS
KING PERFORMANCE ROD BEARINGS
would that work for me? i already know that only the type s pistons take me to 11.5-1
can i use the connecting rods from this set ? without any problems. or use f22c pistons with thicker head gasket and retarding on the camgear i dont know how to calculate the valve to piston clearnce.
Thank you
Old 08-19-2012, 05:49 AM
mtseidl's Avatar
The structural integrity of the bearing will not be effected with or without the oil hole. I drilled the hole in my ACL bearings in my H22A4 and ran them hard for 5 years. Sold the motor a while back, never had any issues.
nemesis25
10-18-2012 04:09 AM
tgh22a
12-09-2005 12:49 PM
pentaq
11-16-2004 03:10 PM
ludesleep
05-08-2003 09:04 PM
Quick Reply: Rod Bearing Differences (Oil Hole) H22A1/A4, H23, F22 etc Help!
