Can this ecu be repaired?
Old May 16, 2012 | 05:58 AM
T-Mo's Avatar
Default Can this ecu be repaired?
Ok so after fidelling around with my car for the past few weeks, I learned that the computer is fried. I've been on the hunt here, CL, eBay, other forums, etc and it seems as though this computer is hard to find for my '96 Prelude Si. So I was wondering if it can be repaired or if it's trash... 37820p14-a13
Old May 16, 2012 | 06:28 AM
typemismatch's Avatar
Honda owns me
Default Re: Can this ecu be repaired?
Looks trashed, looks like the burns go through the board and across circuits.
Get an OBD1 jumper harness and:
You can run a P72 with Crome, Hondata, etc. and keep all your stock functions.
You can run a p28 if you don't mind loosing IAB, EGR and Knock.
Old May 16, 2012 | 07:48 AM
T-Mo's Avatar
So no obd2 ecus can be used? I have access to a p72 obd2 ecu. The main thing I wanna know I guess is what can be used to move the car like now without tuning. My mechanic was recently incarcerated and I need to move the car from the shop. Would the p72 work but run crazy just enough for me to drive it 3-4 miles to the house. Then from there I can get exactly what I need
Old May 16, 2012 | 08:22 AM
Honda owns me
Plug it in, most honda ecus can run other hondas of the same OBD level. Mind you, its not going to run great, and it may be rich/lean so you don't want to run it too long that way. You do have the knock sensor on the P72 which is a benefit, so it shouldn't ping and do major damage.
I've seen a stock P28 run an 800hp B18 on E98 enough to get it in and out of the garage.
Old May 16, 2012 | 08:37 AM
T-Mo's Avatar
Ok thanks for quick response/advice. I will try it out and see
Old May 16, 2012 | 09:36 AM
T-Mo's Avatar
It worked! Ran a lil sluggish (expected) but I made it home. ****sigh***
Old May 16, 2012 | 09:41 AM
Honda owns me
Congrats!
At least you got'er home!
wesley_925
Engine Management and Tuning
May 15, 2008 05:11 PM
mattcivic
Jun 18, 2006 08:57 PM
Zathris226
Sep 17, 2005 05:40 AM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
itr1244
Apr 29, 2005 06:01 PM
