how to replace valvecover thread
Old Apr 16, 2012 | 05:25 PM
97accordbuildlx's Avatar
Default how to replace valvecover thread
i was removing the valve cover on my h22 to replace the gasket etc. and as i removed the valve cover bolts one bolt would continuously spin.
how easy are the threads to replace? i was thinking about just breaking/cutting off the thread above the valvecover so i could get the VC off and then from there just replace the thread. but how do you replace/take off the thread? thanks
Old Apr 16, 2012 | 05:36 PM
Hawkze_2.3's Avatar
Default Re: how to replace valvecover thread
You mean #9?
Old Apr 16, 2012 | 05:43 PM
Originally Posted by Hawkze_2.3
You mean #9?
alright thanks, so it seems as though if i were to break off number 9, then once i remove the valve cover i can just undo the thread with a socket and then replace it correct?
Old Apr 16, 2012 | 06:21 PM
Hawkze_2.3's Avatar
Yessir, you would just need either a new #8 or #9 depending on which one broke off.
Old Apr 16, 2012 | 07:16 PM
okey doke. and i guess next question. i finally got the cover off by cutting the bolt in half and there was dry crusty gunk on the top (panel??) above where the cams and rocker shafts are. i dont know the exact word for it but u have to remove it to get to the cams. (of course only name i dont know in the entire engine) the engine has over 150k on it and im wondering if thats normal or what? there isnt any sludge persay but on the top of the metal part theres just dry black crusty flakes... i changed the oil when i got the car and it was biddlyblack
Old Apr 16, 2012 | 08:11 PM
minilogoguy18's Avatar
Sounds like its been running with low oil so that the head wasn't getting much and with the heat of the engine the oil got baked on there. Keep an eye on the oil and change it more frequently, could also be from the PCV system not working, make sure the hose from the valve cover to the intake pipe is connected along with the one from the PCV valve to the intake manifold.
Old Apr 16, 2012 | 09:10 PM
yea it had a gnarly oil leak not too long ago it was in the back of the engine it was the oil filter oil seal or whatever so it would leak out as fast as u could pour it in unfortunately i had to drive it a hint below the low dot for a few days before i could fix it. besides that, when i got the car, it had really sludgey oil i just shook my head but ive redrained it twice in the past month and a half to get all the excess blackoil out and it seems to be clear and at the full line. but yea i will check the lines
Slowbro98EX
Engine Machining & Assembly
Mar 12, 2017 09:12 PM
Kaotyk
May 15, 2009 06:00 AM
EJcharlie
Apr 27, 2008 08:36 AM
Import Prelude
Apr 18, 2007 02:50 PM
Hybrid 350GT
Aug 29, 2004 01:20 PM
