Idle problem with H23A Vtec
Old Apr 16, 2012 | 02:25 PM
catchdz's Avatar
Default Idle problem with H23A Vtec
i have a question, i put the h23a into my 96 prelude si, when i went to plug everything in the iacv was different so i put the top of the intake & TB on from my h23a1. now i have a problem with it idling at like 1500 to 2000 rpms, i changed the iacv for a new one, nothing happened still messed up, so i put and old one on and nothing im not sure what to do. when i was messing around with the car one day i realized that my cold air intake was really loud so i took it off, thinking the filter was dirty. As i was F&(ing with things i cover one of the holes with my finger and the idle dropped back down to normal so i tried covering both holes the car wants to cut out, does ne one have ne ideas about what the hell is going on??????
Also i coverted everything back to obd1 and i am using a chipped p06
Old Apr 16, 2012 | 08:24 PM
minilogoguy18's Avatar
Default Re: Idle problem with H23A Vtec
Ignition timing and doing the idle learn procedure would be 2 good places to start. Download the manual from spoonertuner.com if you're not familiar with how to do the idle learn procedure.
Old Apr 17, 2012 | 11:25 AM
catchdz's Avatar
thanks ill see whats up with that? if u think of ne thing else hit me up
Old Apr 19, 2012 | 07:24 AM
Rosko's Avatar
What do you mean by "chipped P06"? Was it dynotuned for this setup? Ignition timing and fuel are probably incorrect for you application causing your erratic idle.
Old Apr 19, 2012 | 12:21 PM
catchdz's Avatar
yeah it was chipped and tuned for my car but i dont think ne of that is the problem i changed the piece that sits under the throttle body the bypass or what not i changed that and most of my problems went away for the most part, i thank u both for ur help. Do u guys know me thing about a code 9 i cant get rid of?
DC2andED6
May 9, 2009 02:55 PM
alexdbest2000
Dec 14, 2008 01:05 PM
supradrifter
Dec 19, 2006 08:43 AM
lilCivic
Feb 2, 2005 05:36 PM
walsredprelude
Oct 30, 2004 09:42 AM
