something is not right help!
Old Jun 22, 2005 | 06:56 PM
xxredpreludesixx's Avatar
Default something is not right help!
ok somethin is not right i have posted and searched on this topic but to no good things to come out of it. So i first start my car and everything is all good pulls an accelerates like normal, but when it heats up and i drive it for awhile it doesnt it accelerates like slower than a stock crx its bad it didnt do this until after i hit the stupid deer a couple weeks back, im getting a knock sensor cel but have been getting for way longer then before i hit the deer almost a month or 2 before i just got my knock sensor and am planning to install i as well did a tune up and oil change to remedy problem but that did not fix it.
any help would be greatly appreciated thank you
Old Jun 22, 2005 | 09:41 PM
Fongman's Avatar
Default Re: something is not right help! (xxredpreludesixx)
any check engine light?
Old Jun 23, 2005 | 03:40 AM
Default Re: something is not right help! (Fongman)
yea the knock sensor light but that has been on for about 2months and this just started happening
Old Jun 23, 2005 | 05:51 AM
IHateJDM's Avatar
you shouldn't drive around with a knock sensor cel on that cel is to help protect from detonation i would bet there is something wrong with your timing and it just finally got bad enough to make your ecu retard the hell our of your ignition timing making it drive so slow just a guess but you should really solve the knock cel and i bet it'll fix your problem isn't it a pain in the *** to read a post without punctuation?
Old Jun 23, 2005 | 10:00 AM
Default Re: something is not right help! (IHateJDM)
no not really hahah but im typing at work and very fast. So yea i plan on fixing the knock sensor cel prob tonite actually i have it im just waiting to use my friends lift to do it
skylerreniger
Jan 19, 2013 04:34 PM
spoon93
Dec 6, 2007 12:59 PM
lshatch92
Feb 13, 2006 06:34 AM
xXx Justin xXx
Jun 11, 2004 02:01 AM
qwklude82
Jan 13, 2003 10:31 AM
