H22 help!!
Old Jun 21, 2005 | 06:41 PM
black92lude's Avatar
Default H22 help!!
Ok well i recently got my h22 civic running and i was throwing a code 7 which is the tps. Today i got the tps figured out and it is not throwing it anymore. However now i am throwing a
12-EGR
22-vtec pressure switch
The car feels kinda sluggish. When vtec kicks in it feels good throughout 6000 but just won't go after that. The rev limiter hits at various places, sometimes it will hit about 6500 and somtimes about 7000 but feels like it doesn't want to go at those rpms. thanks in advance for any help
Old Jun 21, 2005 | 10:14 PM
SKDRCR's Avatar
Default Re: H22 help!! (black92lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black92lude &raquo;</TD></TR><TR><TD CLASS="quote">Ok well i recently got my h22 civic running and i was throwing a code 7 which is the tps. Today i got the tps figured out and it is not throwing it anymore. However now i am throwing a
12-EGR
The car feels kinda sluggish. When vtec kicks in it feels good throughout 6000 but just won't go after that. The rev limiter hits at various places, sometimes it will hit about 6500 and somtimes about 7000 but feels like it doesn't want to go at those rpms. thanks in advance for any help</TD></TR></TABLE>
Are you sure vtec is kicking in?
Clean the egr, make sure you have sufficient oil pressure.
Old Jun 22, 2005 | 06:59 AM
Default Re: H22 help!! (SKDRCR)
yeah, see that is the wierd thing......vtec does kick in(its loud) I am going to clean the egr today i will update and let you know if the code clears
Old Jun 22, 2005 | 07:13 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black92lude &raquo;</TD></TR><TR><TD CLASS="quote">yeah, see that is the wierd thing......vtec does kick in(its loud) I am going to clean the egr today i will update and let you know if the code clears</TD></TR></TABLE>
That's most likely your secondary butterflies opening.
Vtec should not engage if you're throwing a cel.
Old Jun 22, 2005 | 09:06 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">That's most likely your secondary butterflies opening.
Vtec should not engage if you're throwing a cel.</TD></TR></TABLE>
I am pretty sure its vtec.......i have a prelude si with an h23 and it definetaly doesn't sound like my h22....what i do think it might be is when my car is cold vtec won't kick in...do you think that would throw the code?
I will be cleaning my egr and hopefully that will clear the code....I just need to go get some carb cleaner
Old Jun 22, 2005 | 11:22 AM
ok...i just cleaned out my egr and reset the ecu....it cleared the egr code and threw a code 23 which is the knock sensor. I think i might have read the codes wrong before. Anyways do i jus need to get a new knock sensor?
swpdb16
Apr 23, 2010 10:54 PM
The Destroyer
Apr 8, 2007 07:18 PM
joshb3480
Oct 5, 2006 09:02 AM
optikal_blitz
Jul 22, 2005 07:50 AM
angelgsrteg
Dec 28, 2004 05:29 AM
