ATTS problem
Old Jun 25, 2005 | 04:53 PM
wreckz's Avatar
Default ATTS problem
i have a 99 SH , and just today my ATTS light went on. i know ATTS is for turning corners by transfering torque. is there any way i can fix this problem other than bringing it to the honda dealer? (trying to avoid that for now).
Old Jun 25, 2005 | 05:35 PM
shdriver99's Avatar
Default Re: ATTS problem (wreckz)
ATTS computer will flash the code just like a regular ecu. Go jump the 2 pin connector with a paper clip and find out the code.
Old Jun 26, 2005 | 02:18 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: ATTS problem (shdriver99)
Reset the ECU by pulling off the negative terminal on your battery for 30 seconds to a minute. Hopefully the ATTS light doesn't come back on. Did you get a CE (Check Engine) light also?
If the ATTS light still comes back on, pull the code.
Also, are you dropped? rims? Give us more info.
Old Jun 26, 2005 | 06:18 AM
wreckz's Avatar
yeah the check engine light is also on.
yeah my car is dropped about an inch.
im on stock sh rims.
Old Jun 26, 2005 | 07:08 AM
* B A N N E D *
Default Re: (wreckz)
So the problem is not with your ATTS. It is something else. Whenever the CE light comes on, it will also trigger the ATTS light. Which means your car is in limp mode and ATTS is temporarily deactivated.
Pull the code yourself or go to autozone and ask them to pull the code.
Old Jun 26, 2005 | 07:27 AM
wreckz's Avatar
thanks ;]
Old Jun 26, 2005 | 07:37 AM
* B A N N E D *
No problem.
Old Jun 26, 2005 | 07:43 AM
wreckz's Avatar
sticky
i think this is the real problem , if you can help me with that?
https://honda-tech.com/zerothread?id=1290223
Old Jun 26, 2005 | 07:46 AM
* B A N N E D *
It could be a vacuum leak or dirty IACV. Look it up and find the problem man. It has beem covered numerous times.
Sam268
Sep 13, 2004 01:11 PM
eL
Oct 25, 2003 05:25 AM
NoLipRacen
Jan 29, 2003 11:27 PM
