headgasket???
Old Jun 27, 2005 | 05:32 AM
bigz187's Avatar
Default headgasket???
I was on the freeway yesterday in third gear @ 6k and all of a sudden the car felt like it misfired, i had noticed that it was running a bit hotter than normal (just a little bit past the half way mark) then all of a sudden the car just died! So i coasted off onto the shoulder and popped the hood and I smelt coolant burning, then i looked underneath the cam gear and saw coolant leaking between the head and the block, so I'm hoping its the headgasket. If so should I go with the OEM honda headgasket or is the a better brand to go with to deal with the type s pistons compression?? I need all the input I can get right now, i;m going to pull the head later on today to check it out...thanks in adavance
Old Jun 27, 2005 | 05:33 AM
bigz187's Avatar
Default Re: headgasket??? (bigz187)
I have a 98 base modek lude, that might help! LOL
Old Jun 27, 2005 | 07:24 AM
bigz187's Avatar
nobody???? come on guys......
Old Jun 27, 2005 | 08:20 AM
durand202's Avatar
OEM head gaskets work fine.
Old Jun 27, 2005 | 02:20 PM
sexyblack93lude's Avatar
Default Re: headgasket??? (durand202)
do a compression test, if your compression is good it isnt your headgasket
all 4 cylinders shoul be pretty similar
Red-Rag-B18
Aug 23, 2010 05:33 PM
smash fascism
Oct 27, 2006 12:38 PM
97itr86
Oct 30, 2004 08:51 AM
Chubz
Apr 25, 2002 03:24 PM
BoostedSi
Apr 20, 2002 04:21 PM
