VAFC problem
Old Jun 23, 2005 | 10:19 AM
Superman137's Avatar
Default VAFC problem
ok I have a 92 accord with a h22a in it I'm running the p13. but the problem is that it won't let me rev past 6800 with the vtec controller hooked up. can anyone tell me why? and the only code i'm throwing is a code 41 which it has been on since I did the motor swap.
Old Jun 23, 2005 | 11:13 AM
4LugR's Avatar
Default Re: VAFC problem (Superman137)
check, check and re- check all your wiring for the VAFC...
Old Jun 23, 2005 | 12:05 PM
The Weather Man's Avatar
What he said
Old Jun 23, 2005 | 12:09 PM
killa_lude's Avatar
make sure when your splices on the ECU wiring actually are cutting through. That was the problem with mine. Good Luck.
Old Jun 23, 2005 | 06:20 PM
The Phil's Avatar
Default Re: (NaptownKing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NaptownKing &raquo;</TD></TR><TR><TD CLASS="quote">What he said </TD></TR></TABLE>
Explain why you even bothered to respond.
Old Jun 23, 2005 | 07:59 PM
mgags7's Avatar
code 41 = get a new o2 sensor....
thats not the problem...
you did either, or both, of these:
1) did not hook up the blue wire (vtec oil pressure) up right....
2) did not splice the vtec wires the right way
just go back and make sure everything is ok with that.....
Old Jun 24, 2005 | 05:01 AM
JTCdudeman's Avatar
Master H Technician
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">code 41 = get a new o2 sensor....
just go back and make sure everything is ok with that.....</TD></TR></TABLE>
Old Jun 24, 2005 | 07:27 AM
IHateJDM's Avatar
Default Re: (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">
Explain why you even bothered to respond.</TD></TR></TABLE>
hopefully that was his 5th and last post of the day.
Old Jun 24, 2005 | 08:46 AM
Default Re: (IHateJDM)
I just reset it and didn't mess with anything but the cylinders and sensors and that did it. Thanks for all the help guys
GSE980
May 28, 2006 11:09 AM
Superman137
Jun 24, 2005 08:48 AM
tegon-gsr
May 2, 2004 06:27 AM
topsekret
Dec 22, 2002 05:49 PM
