noises when turning
Old Jul 18, 2005 | 11:33 AM
BB6racer's Avatar
Default noises when turning
so i've started hearing this noise lately whenever i turn to the left. taking a slow left turn doesn't do it, i have to be pushing a little. i though maybe the axle was coming loose from the transmission, or the control arm was rubbing, but these all seem to be OK. it sound like a clunking noise, and i think it's coming from something that i spinning. i don't feel any jerks from the car, so it can't be a huge problem, and there are no visible sign of anything wrong from underneath either. anyone have any advice?
Old Jul 18, 2005 | 11:39 AM
94vtecmn's Avatar
Default Re: noises when turning (BB6racer)
Its your CV joint on the axle. Check the rubber boot where the axle bends, that's where your CV joint is on the axle.
Old Jul 18, 2005 | 01:30 PM
lewdude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BB6racer &raquo;</TD></TR><TR><TD CLASS="quote">so i've started hearing this noise lately whenever i turn to the left. taking a slow left turn doesn't do it, i have to be pushing a little. i though maybe the axle was coming loose from the transmission, or the control arm was rubbing, but these all seem to be OK. it sound like a clunking noise, and i think it's coming from something that i spinning. i don't feel any jerks from the car, so it can't be a huge problem, and there are no visible sign of anything wrong from underneath either. anyone have any advice?</TD></TR></TABLE>
I just had this problem. My upper balljoint was gone, replaced that and that damn noise is still there. It is when I turn the wheel all the way to the left or right and it gets to the end of the wheel, I hear this PING noise like the "O" ring on the axle or the CV joint is popping out...but nothing actually breaks or pops out.
Not sure what it is now, I will have to get someone to turn the wheel while I crawl underneath to find out where the noise is coming from.
I also heard the noise coming from the rear end at the same time the front made a noise. More like a creaking noise, but it could just have been noise traveling through the car to the rear end....I hope
Hope this helps.
Old Jul 18, 2005 | 02:58 PM
AnthonyG2003
Guest
Posts: n/a
I have the same problem, EXCEPT the noise that I hear is a clicking noise when I am turning. I know it is coming from the right side, but I have no idea what it is. I was told by some people that it is prolly my CV joint but I havent had time to look at it nor have it fixed. If you or anyone else figure out what the problem is for sure...Then let me know that way I can look at mine and have an idea of what it is that might be wrong. Thanks! ~Anthony
Old Jul 18, 2005 | 07:40 PM
BB6racer's Avatar
i'll check the CV joint and let everyone else with this problem know how it turned out. thanks for all the help guys!
Old Jul 18, 2005 | 07:54 PM
MNsnowdaboy's Avatar
check all the areas by the cv boots to see if there's any grease, if yes then your boot got torn and the ball bearing things in the boot are rubbing together, just replace the axles.
Old Jul 18, 2005 | 10:30 PM
K-Spec's Avatar
does it happen at high speeds (20+ mph) or low speeds (5mph - 10mph)? Is it more of a thumping noise or a clicking noise?
Old Jul 19, 2005 | 09:24 AM
lewdude's Avatar
Default Re: noises when turning (khalal538)
mine is mostly at a dead stop, turning the wheels. the right side makes a loud ping sound, I just had the balljoint replaced so im not sure what mine is until I get underneath the car and have someone turn the wheels.
Sounds like a cv joint for the clicking noise when turning though.
Old Jul 20, 2005 | 08:07 PM
Grease = answer
Old Jul 20, 2005 | 09:34 PM
Techna600f4i's Avatar
Default Re: noises when turning (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem, EXCEPT the noise that I hear is a clicking noise when I am turning. I know it is coming from the right side, but I have no idea what it is. I was told by some people that it is prolly my CV joint but I havent had time to look at it nor have it fixed. If you or anyone else figure out what the problem is for sure...Then let me know that way I can look at mine and have an idea of what it is that might be wrong. Thanks! ~Anthony </TD></TR></TABLE>
If you have clicking you need to go gen a new CV Joint, all your grease has leaked out of the boot and the joint has gone bad,
Old Jul 21, 2005 | 01:22 PM
Default Re: (MNsnowdaboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MNsnowdaboy &raquo;</TD></TR><TR><TD CLASS="quote">Grease = answer </TD></TR></TABLE>
Yup and all the grease will be around the car somewhere in that area. I'll tell you that it'll suck messing with your suspension then all of a sudden you grab a pile of grease ****.
Old Jul 21, 2005 | 09:24 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: noises when turning (Techna600f4i)
My noise happens when I am turning at a low speed and accelerating...If I turn and do not press the gas pedal at all...The noise isnt there! I have no idea what it is!!!
riceforlife
Suspension & Brakes
13
Dec 12, 2007 11:27 PM
accordredliner
Dec 21, 2005 08:14 PM
MOTOCOMPO
Sep 30, 2004 09:26 PM
civicqm
Jan 14, 2004 06:55 PM
GReddy SI
12
Jul 17, 2003 04:07 AM
