NO VTEC....?..help
Old Jul 19, 2005 | 09:25 AM
Sick'Lude's Avatar
Default NO VTEC....?..help
ok so i put my new fly wheel and clutch, and my HONDATA s200 with its p72 ecU..well when i started it up and took it out 4 a test drive i realized i had no Vtec!...it wasnt engading...any1 know what it could be, has it happened to u...i tried my p13 (stock) ecU still NO Vtec! help please
Old Jul 19, 2005 | 09:26 AM
Sick'Lude's Avatar
Default Re: NO VTEC....?..help (Sick'Lude)
its not the wiring, or oil pressure, i do have a ECT sensor which is making the ecu turn the check engine light on. Engine Coolant Temp...but why would it not work because of that well if any 1 can help me id appreciate it..
RON from R&D said it could be that sensor..but how could of it gone bad?i had Vtec before i installed every thing,now i dont?
Old Jul 19, 2005 | 12:11 PM
4LugR's Avatar
if the check engine light is on, VTEC won't work. get it turned off and itll work. the computer goes into limp mode with the CEL on, and won't let it engage..
Old Jul 19, 2005 | 12:29 PM
IHateJDM's Avatar
Default Re: NO VTEC....?..help (AEMPrelude916)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEMPrelude916 &raquo;</TD></TR><TR><TD CLASS="quote">if the check engine light is on, VTEC won't work. get it turned off and itll work. the computer goes into limp mode with the CEL on, and won't let it engage..</TD></TR></TABLE>
nope. Not all cels cause vtec to stop working, and very few cels put it in limp mode.
However, you do need ECT for vtec, since it won't work until the car is warm. Fix your ECT prob, and you will probably have vtec again.
Old Jul 20, 2005 | 08:24 AM
honda3431's Avatar
its a long shot, but VTEC won't work when your cruise control button is down. I doubt this would be your problem but when i got my 93 VTEC i accedently put the button down and i couldnt figure out why VTEC wasnt working. It took my like a week to realize that it was the cc.
Old Jul 20, 2005 | 08:32 AM
h8trix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick’Lude &raquo;</TD></TR><TR><TD CLASS="quote">ok so i put my new fly wheel and clutch, and my HONDATA s200 with its p72 ecU..well when i started it up and took it out 4 a test drive i realized i had no Vtec!...it wasnt engading...any1 know what it could be, has it happened to u...i tried my p13 (stock) ecU still NO Vtec! help please </TD></TR></TABLE>
I don't mean to be off topic or annoying, but shouldn't you break in your clutch the first few hundred miles before you shift in the VTEC range? Just trying to save ya a couple hundred bucks in case you didn't know about the clutch break in period (i know i didn't , but i had someone tell me about it)
Old Jul 20, 2005 | 08:38 AM
honda3431's Avatar
Good point... maybe you should wait a little before you test VTEC again...
Old Jul 20, 2005 | 06:26 PM
Sick'Lude's Avatar
Hey guys before I put the clutch and hondata in the vtec was working fine WITH the check engine light on. I have been just cruisin my car, in the breaking in process... After I installed everything I test drove it and there was no vtec, I used datalogging and that's how I found out my ECT code was on. Any help???
Old Jul 20, 2005 | 09:29 PM
Techna600f4i's Avatar
Default Re: NO VTEC....?..help (IHateJDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IHateJDM &raquo;</TD></TR><TR><TD CLASS="quote">
However, you do need ECT for vtec, since it won't work until the car is warm. Fix your ECT prob, and you will probably have vtec again.</TD></TR></TABLE>
Werd, Only some Cels will make VTEC not engage, ECT could be it, also check your VTEC pressure Switch! that was my problem.
Old Jul 21, 2005 | 12:04 AM
951dc5's Avatar
Default Re: NO VTEC....?..help (Techna600f4i)
is your vss connector unplugged?
Old Jul 21, 2005 | 04:08 AM
Sick'Lude's Avatar
well i beleive i triple checked all wiring,oil is full and clean,ecu wiring is good...Vtec was working at the time i parked my car in tha shop..changed out clutch/fly wheel,took off old ecu put new one in p72/s200,OH yea took off the old piggy-back VAFC but connected everything good!i dunno weird though!now no Vtec.iam not all redlining me sh*t jus wanted 2see how it grabs when Vtec engages,but then i noticed I HAD NO VTEC!
Old Jul 21, 2005 | 09:37 AM
951dc5's Avatar
Default Re: (Sick'Lude)
that's a hard guess now.. since you mentioned VAFC and also changed a new ecu. i believe changing clutch and flywheel shouldnt trouble with vtec but might have something to do with wiring since that was other part of the job.
Old Jul 21, 2005 | 01:50 PM
IHateJDM's Avatar
Default Re: (Prelude951)
If I were you, I would take out the vafc and see if it works.
Old Jul 21, 2005 | 01:53 PM
951dc5's Avatar
i was wondering if the flywheel was not installed correctly..would it effect vtec?
Old Jul 22, 2005 | 05:09 AM
IHateJDM's Avatar
Default Re: NO VTEC....?..help (Prelude951)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prelude951 &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering if the flywheel was not installed correctly..would it effect vtec?</TD></TR></TABLE>
you would have much bigger problems than no vtec if the flywheel isn't in right.
Old Jul 22, 2005 | 05:48 AM
v4lu3s's Avatar
RTFM
vtec wont engage without knowing the proper engine temperature. the requirements for vtec are proper engine temp, moving fast enough, enough oil pressure and the proper rpm. you CAN turn the coolant check off with tunign software though.
but persoanlly i would jsut fix the propblem since no ect menas it will run really rich, which is bad daily driving but to me worse when breaking in.
Old Aug 3, 2005 | 12:33 PM
Sick'Lude's Avatar
ok...do u think tha vtec soleniod went bad? how do they go bad?
famdakam
Apr 12, 2018 09:24 PM
EGThang
18
Jun 6, 2008 03:26 PM
2.2 teg
Jun 4, 2007 09:47 PM
92lsvteceg6
Jan 21, 2005 07:29 AM
grlstockb18c1
Nov 3, 2004 07:07 PM
