Type-S Front Cut
Old Jul 23, 2005 | 12:04 AM
st3alth's Avatar
Default Type-S Front Cut
Possibly looking into getting a complete front cut including gearbox for my non SH lude...
Now should I basically have everything i need for the engine/manual conversion? OR would I be need extra parts etc?
Any help would be much appreciated
Modified by [ S7H ] at 1:32 AM 7/23/2005
Old Jul 23, 2005 | 08:42 AM
steveobb4's Avatar
Default Re: Type-S Front Cut ([ S7H ])
If you get a front clip you should have pretty much all of it.mounts,tranny,ecu,clutch dampner(if 5th gen have this also)pedal assemblys.
Old Jul 23, 2005 | 05:30 PM
st3alth's Avatar
Yeah I thought this also.. but I reckon maybe missing a few things... like gauge cluster etc?
Old Jul 23, 2005 | 06:07 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: ([ S7H ])
if it realy is a type s (97-01) you'll have the type s strut bar bolts your lookin for
and you dont need the guage cluster as far as i know they plug in the same but a auto cluster works with a 5speed conversion if it has every thing like peadles clutch lines shifter and cables it should be just fine but i just remembered about the right hand drive so dont know if the hard lines will work... guess you gotta do a RHD conversion
Old Jul 23, 2005 | 08:06 PM
1-Bar's Avatar
Default Re: (raylude)
the hardlines from the master --> slave is different since its on the opposite side, you are correct Raylude. As for the shift linkage, they are the same length so it will work. Actually if I remember correctly the JDM are made better then the USDM ones, they are a lot thicker and less prone to break on you.
Also if your getting a Type-S front clip, then that comes w/ ATTS. The SiR Version comes w/o and probably better suit for your Base-S model....
Old Jul 23, 2005 | 11:38 PM
st3alth's Avatar
type-s front cut is from Japan.. so its right hand drive also.. no need for a conversion
Old Jul 24, 2005 | 08:48 AM
steveobb4's Avatar
Yep i used the shift linkage from my 4th gen clip also. Along with all mounts/radiator/injector resistor/clutch pedal assembly. Still have a ton of extra stuff
Old Jul 24, 2005 | 04:03 PM
st3alth's Avatar
4th gen parts can be used on 5th gen conversion?
Old Jul 25, 2005 | 06:12 AM
steveobb4's Avatar
No i meant i bought a 4th gen clip and used that stuff.
joel.j.tellez
Aug 4, 2013 05:38 AM
meanshyguy
Feb 24, 2009 01:27 AM
mike integra
Sep 17, 2008 06:29 PM
xXSilentScreamXx
Sep 30, 2007 04:42 PM
98savage
Apr 4, 2007 03:47 PM
