idle ??
Old Jul 18, 2005 | 03:19 PM
h22831's Avatar
Default idle ??
my honda prelude 2001 .. h22a. is having idle problems. my rpm gauge jumps. from 1 to 2,000 rpms. .. can someone halp me
Old Jul 18, 2005 | 03:33 PM
eMpAtHy's Avatar
Default Re: idle ?? (h22831)
sounds like a vaccum leak. check to make sure all ur vaccum hoses are on. make sure everythign connected to the intake manifold is tight.
Old Jul 18, 2005 | 05:42 PM
eric416's Avatar
do a search for how to clean your fast idle valve. its below the throttle body
Old Jul 18, 2005 | 06:22 PM
shdriver99's Avatar
Default Re: idle ?? (eric416)
Fast idle valve is indeed beneath the throttle body for one thing but I doubt that's the problem. Second a vacuum leak isn't likely to make your idle bounce between 1000+2000 rpms. Vacuum leaks usually raise the idle period. I'd check voltage on the tps and check your idle air control valve!
Old Jul 18, 2005 | 06:36 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: idle ?? (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a vaccum leak. check to make sure all ur vaccum hoses are on. make sure everythign connected to the intake manifold is tight.</TD></TR></TABLE>
Sounds like a vaccum leak.
IntegraType-R
11
Jan 20, 2008 11:23 PM
egCoupe
10
Aug 12, 2005 12:54 PM
94SHOWLS
Feb 17, 2005 12:31 PM
4gen
Jan 11, 2004 05:28 PM
DxTrix
Dec 24, 2003 08:59 PM
