Adding oil without draining.
Old Jul 23, 2005 | 12:26 AM
Unlimitationz's Avatar
Default Adding oil without draining.
Ok here is the deal. I have a high mileage (157k) 1998 Honda Prelude. I did a drain and fill oil change 1 month ago. And now it's already at the minimum dot stage.
The question is, can I just add a few quarts into there without draining the old oil out? I mean the whole point of draining it out is because its dirty, but its not because I just changed it 1 month ago and it just got all burned.
Basically my H22 burned all the oil, so can I add a few quart into it w/o draining old oil out? Will it harm engine in anyway? Thx.
Old Jul 23, 2005 | 01:05 AM
eMpAtHy's Avatar
Default Re: Adding oil without draining. (Unlimitationz)
add a bottle and turn on ur car for a minute or so and let the oil run through and then turn it off and check it again. make sure ur car is on flat ground when u test it. it dosent help to test it when ur car is on a friggin hill cause it'll screw up the results.
Old Jul 23, 2005 | 09:42 AM
Default Re: Adding oil without draining. (eMpAtHy)
Thx empathy, I appreciate the response.
TomTomTuning
Honda S2000
32
Jul 5, 2006 06:16 AM
DVS Luder
Oct 24, 2004 01:55 PM
KCLude01
Oct 13, 2003 01:27 PM
94thundergrey
Nov 12, 2002 12:55 PM
tensai717
Dec 9, 2001 03:49 PM
