idle problem
Old Jul 22, 2005 | 12:40 PM
majek's Avatar
Default idle problem
My friends h22a1 idles at 1200rpm warm or cold dont matter but when when u cover the top hole in the throttle body the idle drops back down to normal. What controls this top hole in the throttle body. Please help thanks
Old Jul 22, 2005 | 12:57 PM
majek's Avatar
Default Re: idle problem (majek)
Another thing it idles at 1200rpm when we unpluged the iac valve before this it use to idle at like 2500rpm so the iac is still good right.
Old Jul 22, 2005 | 02:34 PM
majek's Avatar
anyone please help does he need to get a new iacv
Old Jul 22, 2005 | 07:27 PM
Slavko's Avatar
The top hole on the throttle body with a short tube sticking out right? If so, then that goes straight to the charcoal canister. You can plug that hole up and throw out the charcoal canister or just run a vacuum line from it and connect it to the charcaol canister.
Old Jul 22, 2005 | 09:20 PM
majek's Avatar
no the top hole inside the throttle body
Old Jul 23, 2005 | 07:00 PM
PrettyLude's Avatar
its ur fast idle thermal valve
Old Jul 23, 2005 | 07:11 PM
shdriver99's Avatar
Default Re: (PrettyLude)
I've got a fitv too I don't need and it works. I thought it was causing my car to stall on startup when indeed I found out it was my dizzy. I kept the new one and the old one sits here! I had it on ebay for 20 bucks shipped nobody bought it lol!
Old Jul 23, 2005 | 08:41 PM
95ONE's Avatar
Sounds like either the Fast idle or the IAC. The fast idle valve backs itself off some threads in there and the wax pintle doesn't get a chance to close itself off. Buy whatsisnames ^ Fast Idle valve and See if it works. It will probably help. Then plug in your IAC. If the idle goes up. Get another IAC. Problem(S) solved. meaning this could be more than one thing.
Da9austinRacing
Jul 24, 2011 07:22 PM
magicguy
Jan 30, 2009 02:00 PM
black bandit
Jan 14, 2008 04:26 AM
Accord15
Oct 22, 2002 01:34 PM
FourthGenHatch
Apr 29, 2002 11:08 AM
