Brak
Old Jul 23, 2005 | 07:50 AM
AnthonyG2003
Guest
Posts: n/a
Default 4th Gen BRAKE PEDAL....
Guys, When I push in my brake pedal it starts out stiff like the brakes are working and then it starts to gradually lose the pressure and starts to sink towards the floor. I was wondering if it would actually be the brakes (before i change them) or if it might be the master cylinder (hopefully not)....
Old Jul 23, 2005 | 07:52 AM
LudemanDan's Avatar
More than likely it's the cylinder
Old Jul 24, 2005 | 11:37 AM
h8trix's Avatar
Default Re: (LudemanDan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudemanDan &raquo;</TD></TR><TR><TD CLASS="quote">More than likely it's the cylinder </TD></TR></TABLE>
It could be, but first try bleeding your brakes first or have it done somewhere. You may also be running crappy fluid. I think most brake fluid is clear or a clearish color. If its dark, murky, or has sediment in it you definetely have to get all that fluid out. So...
1.) Check fluid in the master brake cyclinder. Make sure its between the min and max lines and that the fluid still looks good.
2.) Bleed the brakes.
3.) Do the brake tests in the Helms manual if problem still persists.
4.) Replace whatever failed the test first in the order of the Helms manual testing procedure.
I don't know which gen you have, but I could summarize some of steps for these if you have a 4th gen
Chev
14
Oct 20, 2017 03:32 PM
PhilE2212
Suspension & Brakes
Nov 7, 2012 10:08 AM
PhilE2212
Nov 2, 2012 08:26 PM
ILcrxsi1
May 28, 2006 01:27 PM
robbin
Apr 26, 2004 01:53 PM
