Using temporary P14 ecu with H22
Old Oct 25, 2005 | 05:52 AM
Kwaakku's Avatar
Default Using temporary P14 ecu with H22
Is that possible? Which wiring I have to use?
Old Oct 25, 2005 | 05:53 AM
MrBiggs's Avatar
B A N N E D
yeah its possible. Change your fuel injectors to 240 and you'll be fine.
Old Oct 31, 2005 | 11:46 AM
Kwaakku's Avatar
Default Re: Using temporary P14 ecu with H22 (Kwaakku)
How about tryin h22's p13 ecu in my h23?
Is that possible?
Old Oct 31, 2005 | 11:53 AM
veganej's Avatar
i dont see why you couldnt do either as long as the correct injector size is corresponded, only thing is with a p13 on an h23 the maps may be different bc of vtec.
Old Oct 31, 2005 | 11:55 AM
The Weather Man's Avatar
Yep. If the injectors are corresponding, it will work. I had my p14 running my h22a for a while. I have 240cc injectors in there.
Old Oct 31, 2005 | 12:38 PM
98vtec's Avatar
moderator emeritus
Default Re: (TheKingPin)
if i could run an OBDI p75 (ls teg) without problems, you can run an p14.
Old Oct 31, 2005 | 03:05 PM
yOnKiNaToR's Avatar
Default Re: (98vtec)
it can be done (i ran it that way b/c i had to for about 3 months) but i would recommend taking it easy. dont' rev it high or punch it b/c the timing maps are in the p14 are not designed for vtec or reving high
Old Nov 3, 2005 | 06:48 PM
Gillard82's Avatar
Default Re: (yOnKiNaToR)
i also ran my H in a p14, it works but deff. dont rev high or punch it like yOnKiNaToR said. Deff. consider buying the correct ecu tho, i got one PM me.
PremiumPrelude
Mar 12, 2008 01:25 PM
waynecoSI
Feb 19, 2008 01:51 PM
preludefien
Jan 16, 2007 10:45 AM
SUB-0 H23
Oct 29, 2003 06:47 PM
willhoman
Jun 12, 2003 01:00 PM
