Problem.... with engine
Old Oct 27, 2005 | 04:56 PM
Lenne's Avatar
Default Problem.... with engine
I have a 99 prelude with a Greddy bolt on turbo kit...
when i run my car and rev it up.. the RPM drops really low
sometimes low enough to kill the car... I have no idea what it is..
i have no i checked all my hoses.. the fuel rail is sending more than
enough fuel.... also it idles really low.... about 750-810rpm..
but when i let go of the throttle for some reason it drops to 550-675rpm
sometimes the high 400's then the car dies.. any ideas??
ive looked and i have no clue whats going on...
Old Oct 27, 2005 | 05:07 PM
jdmh22luda's Avatar
Default Re: Problem.... with engine (Lenne)
sounds like an iac valve, controls idle
Old Oct 27, 2005 | 05:18 PM
Lenne's Avatar
how can i mess around with that?
can it go bad although i havent touched it??
it started acting wierd a few days ago and today the **** dies on me...
i just added fuel injector cleaner.... could that be an issue??
i have...
Walbro furl pump
AEM fuel rail
AEM fuel pressure regulator..
i think i have injectors...
Modified by Lenne at 2:32 AM 10/28/2005
Old Oct 27, 2005 | 05:36 PM
5200BB6's Avatar
Default Re: (Lenne)
i have same problem but mine dies every time i stop. my revs also drop like you explained. if you find a fix for this, please post.
Old Oct 27, 2005 | 05:40 PM
Lenne's Avatar
are you boosting also??
by the way the car doesnt like to start either...
the only way i can start it is click the keys twice to let the pump, pump some fuel...
pump the gas 4 times slowly.... 1 one thousand, 2 one thousand... that slow..
try to start it and then i have to give it some gas.... and sometimes it dies immediatly...
Old Oct 27, 2005 | 06:00 PM
preludeshdriver's Avatar
Default Re: (5200BB6)
I used to have this same problem until I wrecked my 97 SH. One day I took out all my sub and my amplifiers to cusomize my trunk. For an entire 24 hours it acted perfectly and the needle stocked where it was supposed to after reving.
The next day my car was back to normal despoite the fact I had not reinstalled any of the car audion. This make me believe that is was somehow an electrical issue.
Please keep inmind I had tons of A?M parts, an aem ems and in need of a tune. My problem was severe and it stalled everytime I reved and let off.
Old Oct 27, 2005 | 06:05 PM
H0ndaJunkie's Avatar
Default Re: (preludeshdriver)
Have you tried something as easy as adjusting the idle? or replacing the fuel filter?
A messed-up IAC valve usually makes the idle fluctuate up and down.
Old Oct 27, 2005 | 08:24 PM
Lenne's Avatar
how do i adust the idle..
I think that could be the issue;..
cuz when its cold it runs fine.. but at a below normal rpm.... but it doesnt almost stall or die...
Old Oct 27, 2005 | 08:38 PM
prelude1897's Avatar
Default Re: (Lenne)
Clean your IAC and EGR valves, and if that doesn't help, maybe you need to do a valve adjustment. Awhile back my car would die every time I stopped, and once I did a valve adjustment, it stopped
Old Oct 28, 2005 | 12:33 AM
Lenne's Avatar
by the way im using an S2K oil filter from honda
Old Oct 28, 2005 | 12:44 AM
BDRphaSe2's Avatar
i dont know how much your car was like mine, but mine had simular features..when i pulled my cruse control out...i noticed that the vacuum line was punchered somhow, but anyways i ripped it out and took a vacuum line plug and plugged it at the intake manifold, after that it worked fine and my idle was perfectly normal and it ne er acted up again, not saying this is your problem but it could possibly be a vacuum leak,
Old Oct 28, 2005 | 09:32 AM
Lenne's Avatar
i just added fuel injector cleaner not to long ago...
Old Oct 28, 2005 | 10:26 AM
Hawkze_2.3's Avatar
Default Re: (Lenne)
Have you tried removing your bolt-on turbo kit to see if the engine runs good on its own??
Old Oct 28, 2005 | 11:09 AM
JG Luder's Avatar
Default Re: (Hawkze_2.3)
Has it done it the entire time the turbo kit has been on there? If so then I'd say a vacuum leak.
If not, then I'd start with the IAC, maybe even the TPS (I've seen that cause almost any idle problem imaginable). Vacuum leaks are a bitch.
Old Oct 28, 2005 | 05:35 PM
Lenne's Avatar
no i ran about 8k with the turbo...
no problems before this one...
Old Oct 28, 2005 | 09:49 PM
SpeedFreak77's Avatar
Default Re: (Lenne)
I would guess the IAC also. By the way the manual from the dealer says that you should have your idle set at 500-550 so if that is where it's at you are good there and I would look at something else other than the IAC.
Old Oct 29, 2005 | 04:42 PM
Lenne's Avatar
i just noticed that there is engine oil coming from my BOV...
Old Oct 29, 2005 | 04:57 PM
SteveoBA8's Avatar
Default Re: (Lenne)
DAMN! is your compressor seal shot or what?
Old Oct 30, 2005 | 08:47 AM
JG Luder's Avatar
Default Re: (Lenne)
Sounds to me like you need to spend an afternoon tracking that down.
Old Oct 30, 2005 | 12:22 PM
Lenne's Avatar
i took the intake pipe off off the turbo and there was a little oil in that... after i cleaned it it starts fine...
just has that idle problem...
but it doesnt die no more...
any ideas what it could be?
i think my piping might be clogged...
especially my intercooler....
but im wondering what caused it to be clogged
I think some of the turbo seals are going........
from the symptoms...
Modified by Lenne at 10:25 PM 10/30/2005
Old Oct 31, 2005 | 07:18 PM
Lenne's Avatar
bump.... sorry for the double post i just need more opinions...
br8crumb
May 22, 2014 04:53 PM
SilverEK96
May 17, 2013 04:09 PM
Frost7177
Mar 25, 2007 08:27 AM
Lenne
Oct 27, 2005 05:31 PM
