Injectors ???
Old Oct 30, 2005 | 12:15 PM
lude98SH's Avatar
Default Injectors ???
The 97+ preludes run 340 cc injectors right ? Would 370 cc injectors be too big on a prelude with no internal work running n/a ? Also would it be any benefit ?
Old Oct 30, 2005 | 12:33 PM
LuderCriS's Avatar
Default Re: Injectors ??? (lude98SH)
its only 290 i believe
Old Oct 30, 2005 | 02:42 PM
MLBZ521's Avatar
Default Re: Injectors ??? (PreludeRGuY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeRGuY &raquo;</TD></TR><TR><TD CLASS="quote">its only 290 i believe</TD></TR></TABLE>
Correct! OBD2 (96? 97+) H22's use 290cc injectors.
An OBD1 ('92 - '95) H22's use 345cc injectors.
So I would say that 370cc's would be to much just swapping. You would need a tuning computer (ECU) that can control them. That might work at least.. I dunno.. Heh..
Also the OBD1 345cc injectors are Peak & Hold and use a Resistor Box or something or another.
I forgot what the OBD2 290cc injectors are called at the moment..
Oh well, maybe someone else can fill that in..
Old Oct 30, 2005 | 03:11 PM
EGmikeH22's Avatar
* B A N N E D *
they're called saturated i believe, and do you need more than 290 or 345? how much power are you pushing?
Old Oct 30, 2005 | 03:57 PM
lude98SH's Avatar
Default Re: (EGmikeH22)
an H22a4 with h/i/e, high flow cat, and some ignition upgrades. I hear like a ticking sound that sounds like its coming from the injectors thats why I'm asking just to see how im gonna work this. New injectors or clean the old ones up ? cause im not even sure if its definitly the injectors.
Old Oct 30, 2005 | 04:19 PM
98vtec's Avatar
moderator emeritus
Default Re: (lude98SH)
injectors make a clicking noise. But you really shouldnt be able to here it.
97-01 use saturated 290cc injectors
92-95 use peak and hold 345cc injectors
there is no need to run a bigger injector on a stock motor. The stock fuel system is capable of running up to 200whp. beyond 200whp, you will, in most cases need a larger injector
Old Oct 30, 2005 | 04:46 PM
lude98SH's Avatar
Default Re: (98vtec)
So any ideas on wut it is ? Its louder when the engine is cold but is still audible when its warmed up.
Old Oct 30, 2005 | 05:47 PM
98vtec's Avatar
moderator emeritus
natural honda engine tick
Old Oct 31, 2005 | 07:23 AM
kulrevon's Avatar
I would say that the ticking is your valves. maybe get an adjustment?
Old Oct 31, 2005 | 07:56 AM
SKDRCR's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">I would say that the ticking is your valves. maybe get an adjustment?</TD></TR></TABLE>
yep, start with a valve adjustment.
EJ8 GSR-T
Apr 26, 2006 06:33 PM
mprelude
Apr 26, 2005 05:39 AM
Boost3d22
Mar 13, 2005 05:59 PM
caliprelude3087
Sep 2, 2004 12:54 PM
DelsolVtec18
Oct 5, 2001 03:56 PM
