Help - head replacement?
Old Oct 22, 2005 | 10:11 PM
marcaobr's Avatar
Default Help - head replacement?
Tonight after a few runs I noticed a weird griding noise coming from the valves/intake monfld. It only comes up around 2700-2900 rpm (only then) and regardless of gear/neutral, clutch or not. I also noticed that my pilot bearing on my clutch is goind really bad. When clutch is released regardless if in gear or not it throws this other noise.
On the engine would anybody know what it could possibly be? Maybe a bent valve? the car runs perfect and don't even stall or idle bad.
On clutch would it be just the bearings? it's really stiff when shifting even after a fluid change
thanks
Old Oct 22, 2005 | 10:36 PM
Sabbotage's Avatar
Default Re: Help - head replacement? (marcaobr)
Sounds like you may possibly have a failing timing belt autotensioner. Mine sounded the same when it went out and it was roughly at the same RPM level you described.
Old Oct 23, 2005 | 08:19 AM
marcaobr's Avatar
Default Re: Help - head replacement? (Sabbotage)
tensioner? the noise comes from the top of the motor, around intake mnfld... if it was the tensioner wouldnt it be around the cams or pulleys?
thanks
Old Oct 23, 2005 | 10:58 AM
marcaobr's Avatar
anybody else have any other opinion? pelase..
Inextricabledrvr
Oct 22, 2013 10:18 PM
dtran002
Feb 1, 2013 06:02 AM
manyakiexpi
Nov 9, 2006 01:50 AM
paulc
Nov 10, 2005 05:10 AM
echo999
Feb 4, 2002 04:41 PM
