Quick question...
Old Oct 28, 2005 | 09:21 AM
VTecLude1994's Avatar
Default Quick question...
Ok, I never even thought about running synthetic oil in my old '95 Lude with 189k miles. Well my new '94 Lude only has about 92k...you guys think it would be alright to run Mobil 1 Synthetic 10W-30 in it? I believe it will be ok...just wanna check with the pros.
Old Oct 28, 2005 | 09:31 AM
shutta's Avatar
check with the pros 'eh? if that's what you wanted call honda. there are smart guys here but, why woudl synthetic be a bad thing for an old motor?
Old Oct 28, 2005 | 09:34 AM
Default Re: (shutta)
expletive the Honda dealership. I only deal with them if I have to. Reason I'm asking all the Luders on Honda-Tech is because most of them probably run some sort of synthetic.
Old Oct 28, 2005 | 09:39 AM
Mad Hatter's Avatar
Default Re: (94LudeVTec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94LudeVTec &raquo;</TD></TR><TR><TD CLASS="quote">expletive the Honda dealership. I only deal with them if I have to. Reason I'm asking all the Luders on Honda-Tech is because most of them probably run some sort of synthetic.</TD></TR></TABLE>
i use 5W30 synthetic oil...i've heard synthetic oils better for the motor
Old Oct 28, 2005 | 09:41 AM
rawNArsxS's Avatar
mobil1 is wut i use
Old Oct 28, 2005 | 09:43 AM
Hawkze_2.3's Avatar
Default Re: Quick question... (94LudeVTec)
I just put Mobil 1 in my car and it's almost got 170k on it. Runs better now.
Old Oct 28, 2005 | 01:43 PM
StTook's Avatar
Default Re: Quick question... (Hawkze_2.3)
I put in fully Synthetic - but forgot the brand
Old Oct 28, 2005 | 06:25 PM
RemerLex11's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94LudeVTec &raquo;</TD></TR><TR><TD CLASS="quote">I believe it will be ok...just wanna check with the pros. </TD></TR></TABLE>
the pros? ru serious, there are too many 16 yr old ricers on this site, i wouldnt trust 90% of the people here.
Old Oct 28, 2005 | 07:26 PM
mkazm83's Avatar
If the motor is in good condition you'll be fine. Since synthetic oil contain cleaning detergents it might loosen some build up thats keeping some seals from leaking. Youll most likely be fine.
Old Oct 28, 2005 | 09:44 PM
SpeedFreak77's Avatar
Default Re: Quick question... (mkazm83)
You should be fine, I started using Redline in my H22 with a little less miles on it than you have with no problems. If you really wanted to call a dealership just ask to speak with a tech and usually they will give advice without taking your car in.
I have had numerous times where I was having problems removing a part or needed advice on replacing something and gave them a call and got advice. But maybe the head tech at my dealership is willing to help.
Old Oct 28, 2005 | 10:51 PM
JG Luder's Avatar
Default Re: Quick question... (SpeedFreak77)
**** redline. I ran it for 500 miles, drained it, and never looked back.
And whoever said H-T was 90% 16 year old ricers... was 100% correct. I read through some of these answers in this "tech" forum now, and it truly scares me.
Old Oct 28, 2005 | 11:17 PM
RudeLude95's Avatar
You can run Mobil 1. If you don't drive hard, it isn't mandatory...but it is cheap insurance because it is better for the motor.
I use Mobil 1 sometimes, and sometimes I use Honda Genuine. Depends on what the car will be doing.
Old Oct 29, 2005 | 12:24 AM
K-Spec's Avatar
10w30 mobil1 synthetic green cap is "A" ok. I use it along with a mobil1 filter.
I used to use 5w30 mobil1 blue cap but I revv the **** out of the car sometimes and it burns a lot of oil so I switched over to the green cap.
quicksilver1689
Honda Motorcycles
27
Dec 5, 2007 05:44 PM
madswapper
Mar 16, 2005 08:40 PM
TeknikDC2
Mar 6, 2005 07:22 PM
DjFreeze
Jan 31, 2004 08:33 AM
HavokB18
20
May 29, 2003 04:16 PM
