Map Sensor Code
Old Oct 27, 2005 | 11:19 PM
high_revs's Avatar
Default Map Sensor Code
95 h22 swap in a 92 si w/ a p28....car ran fine with swap for 4,000 and the all of a sudden today it started acting up....i changed the map sensor with a spare, still a code.....tried my buddies ecu, and still had a code...i was just looking at a diagram and the map sensor has 3 prongs...i know the middle wire goes to the ecu pinout (d17) im not sure about the other two...might be power and ground???? can any1 confirm this? im gonna try to run a wire straight to the ecu tomorrow to the singal on the map and see if it removes the code, but i would like to know what the other two wires run to...thanx
Old Oct 28, 2005 | 04:21 AM
high_revs's Avatar
Default Re: Map Sensor Code (SB tuning)
bump
Old Oct 28, 2005 | 10:46 AM
high_revs's Avatar
figured it out
Old Oct 28, 2005 | 12:27 PM
bgm93srv's Avatar
Did you get rid of the code? I've been dealing with an intermittent code 3 for two years now and can't get it fixed. Just wondering what you did to take care of it
Old Oct 28, 2005 | 03:37 PM
high_revs's Avatar
Default Re: (bgm93srv)
yep its gone...the 3 big main plugs where the engine harness and dash harness connect, one of them wasnt fully plugged in and it was a bitch to get it to plug all the way in....guess it could lose contact once in a while.
Old Oct 28, 2005 | 05:06 PM
bgm93srv's Avatar
I'm gonna have to look into that. WOnder if that could be my problem as well. Has been happening more consistently lately. I'm willing to try anything that doesn't require me spending more money to fix this problem.
Old Oct 28, 2005 | 11:18 PM
high_revs's Avatar
take a look, it wont kill...let me know the results
FSUseminoleEM1
Feb 19, 2010 08:34 AM
philosofy1
10
Aug 26, 2006 07:35 AM
Groove_D
May 27, 2006 11:40 AM
krz6jdm
Feb 21, 2006 01:36 AM
Frosty_spl
Feb 12, 2002 02:06 PM
