98 Prelude Master Window Problems
Old Mar 29, 2006 | 05:26 PM
dcb284's Avatar
Default 98 Prelude Master Window Problems
just bought a 98 Prelude but the master window switch wasnt working. mirrors dont work either. when i try and push down the passenger side window (on the master window switch) the window does not go down. but when i push down on the passenger window switch the passenger window does go down.
i just bought a used window switch and had it installed. the windows dont go down but the mirrors work. the passenger window switch works perfectly fine.
what could be the problem? i checked the fuses and they look fine
Old Mar 29, 2006 | 05:49 PM
dcb284's Avatar
Default Re: 98 Prelude Master Window Problems (dcb284)
bump
Old Mar 29, 2006 | 06:16 PM
MileHigh's Avatar
do you hear the window motor running as you push the switch for your driver's side window?
you might want to check the wires that connects to that motor
and use like a test light or a multi-meter to test if that switch is good or bad
I replaced my motor yesterday... it's called the window regulator - look up in parts
Old Mar 30, 2006 | 05:11 PM
dcb284's Avatar
Default Re: 98 Prelude Master Window Problems (MileHigh)
i dont hear the motor or anything. could the switch be bad if the mirrors work but the window doesnt? or could it be just the motor/regulator?
Old Apr 3, 2006 | 05:23 AM
MileHigh's Avatar
not sure about the 5th gen
but my 4th gen switchs are seperate wiring units for window and mirrors
Old May 9, 2006 | 05:36 PM
silvercivicgrl's Avatar
my window has been acting funny too.
The drivers side window sometimes will roll down (usually when the car is cool like in the morning or during the evening) But during the day when it is hot it wont roll down...my brother thinks something may have been cold-soldered and when it heats up it looses the connection...is that possible?
eksedan7198
16
Mar 27, 2014 04:14 PM
TyLLy_4
Nov 19, 2010 06:21 AM
Bayhustle81
Aug 31, 2009 01:44 AM
MtbikingKing
May 5, 2006 09:27 PM
berge
Apr 2, 2006 09:59 PM
