Tein Coilover Owners...
Old Mar 24, 2006 | 09:09 PM
SubliminalMsger's Avatar
Default Tein Coilover Owners...
Hey Guys, well I got my tein type-flexes on and love it so far... Here's a pic of them outta the box and a comparison shot:
Everything seems good so far, however there's one thing I'm not sure of. For the fronts, I wasn't sure how far the shocks should sit into the lower container (not sure what to call it, but basically the "cup" that it sits in). Here's are my options:
Right now I have it at B, in other words sitting as far in as it can. The thing that throws me off is those 2 grooves. If you look at the comparison shot, there's a groove on the stock shock that I think is where the bolt ran through. So how did you guys do yours? Any help is greatly appreciated.
Old Mar 24, 2006 | 10:37 PM
05member y0's Avatar
Default Re: Tein Coilover Owners... (SubliminalMsger)
When i INstalled my teins, i put them to what you have labled as B. When the fork is all the way to point "b", the bolt that tightens the fork down sits into the second groove i believe. either way i would put them all the way up as that is where they will want to sit anyways.
Old Mar 25, 2006 | 04:48 PM
Default Re: Tein Coilover Owners... (05member y0)
i see... thanks. anybody else do it differently?
Old Mar 25, 2006 | 05:09 PM
SteveoBA8's Avatar
at B on my type basics
Old Mar 25, 2006 | 05:47 PM
hoehouseworker's Avatar
Default Re: Tein Coilover Owners... (SteveoBA8)
Point B on my Flex's
Old Mar 26, 2006 | 05:15 PM
cruzin89lude's Avatar
point B with the flex's
Old Apr 1, 2006 | 02:31 PM
PreludePhill's Avatar
Default Re: (cruzin89lude)
I just installed the exact same Tein coilovers, which way do you spin the the green collars to lower the vehicle?up or down?and does the third bottom collar stay all the way on the bottom?
Old Apr 1, 2006 | 03:28 PM
4G92's Avatar
i didnt notice that on my super streets hmm... ill take a look.. i only noticed one groove i guess urs can go on either groove since the flexes are height adjustable
Old Apr 1, 2006 | 03:37 PM
im just trying to lower it as low as possible but still drivable.I know the basics of the coilovers but not a ton about the adjusting ride hieght and dampning on it
Old Apr 3, 2006 | 03:18 PM
n20- COMPRESSING the spring will make your ride a little stiffer but your shocks are adjustable so just handle stiffness from there for now. You can lower it that way BUT
the best way to lower it with the setup you have (flex's) is to unhook that lower shock perch and spin the whole fork thing. I'm pretty sure right means lower and spinning it left gets you higher, but you should just try it both directions, it should be obvious which is up or down. that bottom collar should stay at the bottom, tighten it when you're finished adjusting that lower perch.
Old Apr 11, 2006 | 05:51 PM
mrblue13's Avatar
Any of U guys use these for autocrossing? or have the Electronic Damping Force Controller hooked up to it?
Old Apr 11, 2006 | 10:48 PM
Milan0Gsr's Avatar
how much did you pay for them?
Old Apr 12, 2006 | 05:46 PM
Default Re: (Milan0Gsr)
i got em for about 1,200 (slight hook up)
Old Apr 24, 2006 | 08:56 PM
redtop22's Avatar
Modified by redtop22 at 1:32 AM 4/25/2006
portaman03
Suspension & Brakes
Apr 15, 2009 12:22 PM
xoutlawz00x
17
Oct 27, 2005 01:29 PM
xoutlawz00x
Suspension & Brakes
Oct 17, 2005 08:46 PM
beat_nut
Nov 26, 2004 10:41 AM
strict 9 ef
Apr 27, 2003 12:56 PM
