SWAP PROBLEM
Old Mar 31, 2006 | 07:28 AM
uscivicmc's Avatar
Default SWAP PROBLEM
my buddy is in the process of swapping a 92 H23 motor into a 96 body, with 96 ECU, he needs a conversion kit, which kit does he need to get? thanks alot
Old Mar 31, 2006 | 07:38 AM
syntax.'s Avatar
Default Re: SWAP PROBLEM (uscivicmc)
the 96's are OBD2 and i think the ecu's have an immobilizer
consider getting a obd1 ecu, distributor, and a obd2 to obd1 harness. i believe boomslang is a company that makes them.
Old Mar 31, 2006 | 07:57 AM
mgags7's Avatar
all he needs to do is use the distributor and crank sensor off the motor that came in the car, everything else will plug right up (assuming the car was an h23 before)
96preludebn
Dec 12, 2012 10:21 AM
hyperB16Turbo
Jul 8, 2008 07:51 AM
importtuner4130
Jun 20, 2008 03:57 AM
