anti-reversion header?
Old Aug 18, 2006 | 02:22 PM
darkspector2.0's Avatar
Default anti-reversion header?
Is the RMF Header an anti-reversion style?
If not are there any manufactured for the h series
Old Aug 18, 2006 | 02:37 PM
98vtec's Avatar
moderator emeritus
Default Re: anti-reversion header? (darkspector2.0)
no.
Old Aug 18, 2006 | 02:40 PM
gawwwwd damn!! I've been dong some research and anti-reversion seems to be where it's at..
wonder why no-one has done it.. perhaps it's the aftermarket demand is getting smaller?
Old Aug 18, 2006 | 03:13 PM
Speedra500's Avatar
Default Re: (darkspector2.0)
yes, smsp and prospeed, also an-r i believe use anti-reversion pockets and i think smsp has done something with D-shaped primaries to accomplish similiar results
my9thtry's Avatar
would you care to explain exactly what anti-reversion is?
Old Aug 18, 2006 | 03:40 PM
98vtec's Avatar
moderator emeritus
Default Re: (my9thtry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry &raquo;</TD></TR><TR><TD CLASS="quote">would you care to explain exactly what anti-reversion is?</TD></TR></TABLE>
name kinda explains it all. Anti - against, Reversion - reversal
these chambers prevent "air" from traveling back into the combustion chamber after exiting through the exhaust ports, essentially keeping the combustion from getting contaminated with molecules that have already been burned.
Old Aug 18, 2006 | 04:32 PM
Default Re: (98vtec)
headers are tuned by length and diameter...
longer and skinnier primaries help the low end by creating a faster vaccum earlier on.. but lose power in the top end because of constricted flow at higher velocities.
Shorter, wider primaries, well it's the opposite pretty much as above.
also flow between valve overlap caused by cams/timing can cause reversion, the exhaust gases flowing back.
"your goal is to keep the exhaust speed/energy high to maximize cylinder scavaging yet restriction low to reduce back pressure to the minimum and to control and direct reversion pulse energy to assist in that scavaging"
anti-reversion helps prevent reversion, duh, keeping your scavaging efficient
if my thoughts are wrong or confusing... since i'm tired... here
http://www3.bc.sympatico.ca/Vo....html
http://forums.hybridz.org/showthread.php?t=102100
Old Aug 19, 2006 | 11:26 AM
ilikehonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">headers are tuned by length and diameter...
http://forums.hybridz.org/showthread.php?t=102100</TD></TR></TABLE>
nice work good sir
Old Aug 19, 2006 | 06:36 PM
mgags7's Avatar
another thing to consider is collector design in regards to anti-reversion...
rmf 4-1 headers use a collector that creates and effective "vortex" in the collector due to the fact that the pipes come together so that they fire one after the other in a circular motion, creating a swirling motion which helps in pulling gases from the other pipes....
Old Aug 19, 2006 | 08:03 PM
my9thtry's Avatar
Default Re: (mgags7)
which collector design are you talking about?
Old Aug 19, 2006 | 08:07 PM
98vtec's Avatar
moderator emeritus
merge/megaphone
kaj
Jan 11, 2008 03:29 PM
coolgsrguy
Mar 26, 2006 12:17 AM
GIANT
33
Jan 28, 2005 01:13 PM
SpoonFedHatch
Apr 26, 2004 02:34 PM
kwik92hb
Mar 9, 2004 04:44 PM
