alternator problems
Old Aug 21, 2006 | 01:53 PM
rasta420's Avatar
Default alternator problems
just replaced an alternator on my friends 2001 prelude SH. it runs fine now, but when i come to a stop and the car is idling, the battery light and brake light (on the dash) comes on. if i hit the throttle or once i start driving, the lights turn off. i thought it was a defective alternator so i tried another good alternator, and the same thing is happening. anyone know what this could be?
Old Aug 21, 2006 | 04:23 PM
JasonST's Avatar
Default Re: alternator problems (rasta420)
First off, manually test the battery voltage with a voltimeter. Make sure it's close to 14.5V when the car is on, if it's not u got a problem. If it is, check all the connections, the cable going to it, the green 4 pin connctor, all the way back to the fuse box.
Old Oct 2, 2006 | 10:21 AM
veetak's Avatar
Default Re: alternator problems (JasonST)
My car is doing the same thing, and my raido has a built in battery meter that says over about 1500 rpm or so I'm at 14.2 volts but at idle I'm only at 12.2 volts. Any suggestions?
Old Oct 2, 2006 | 04:46 PM
slamdlude's Avatar
Default Re: alternator problems (Silver92Lude)
possibly a bad ground to the battery or alternator. or just bad battery.
b16_swap
14
Mar 30, 2011 07:25 AM
JasonYo
Sep 1, 2010 10:42 PM
88 EF Hatch
Sep 17, 2009 07:29 AM
EG6R
May 10, 2007 01:57 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
