# 8 TDC Sensor
Old Aug 21, 2006 | 04:04 PM
TypeSxtacy's Avatar
Default # 8 TDC Sensor
hey guys i got this CEL, just woundering where i can find the TOP DEAD CENTRE SENSOR so i can check if it is connceted!!!
Old Aug 21, 2006 | 04:17 PM
JasonST's Avatar
Default Re: # 8 TDC Sensor (TypeSxtacy)
More info plz. What year prelude u have? Obd2 or obd1? If it's obd1 it's inside the dizzy, and I don't think u can replace it without getting a whole new dizzy. What symptoms and problems are u having besides the cel?
Old Aug 21, 2006 | 04:19 PM
TypeSxtacy's Avatar
Default Re: # 8 TDC Sensor (JasonST)
2000 lude...obd2 ecu...its a type S engine JDM, shop wired into the dizzy from the crank to allow it to start, wont rev past 3 thous rpm, rough start up!!
Old Aug 21, 2006 | 08:04 PM
JasonST's Avatar
I might be wrong but I think with obd2 ur TDC sensor should be in the engine, try searching for TDC in archived info, yeah with that cel ur car won't run very well at all until it's fixed. Bump.
Old Aug 23, 2006 | 04:27 PM
h22silvia's Avatar
its in ur distributor. u need a new distributor. base from experience had the same problem
Old Aug 23, 2006 | 05:08 PM
mgags7's Avatar
make sure the shop that did the work did the wiring correctly, that sensor does not really go bad, its a very simple sensor, just a magnetic pickup that reads off the distributor shaft....
check the wiring from end to end....
Unphzd
Dec 13, 2010 11:30 PM
rx7_dude2003
Nov 30, 2009 03:06 PM
hondasport2000
Aug 14, 2009 01:18 PM
LudeCris
Feb 3, 2006 09:47 AM
blufke
Apr 6, 2003 05:10 PM
