Knock Sensor
Old Aug 16, 2006 | 10:58 PM
jdm00civicex's Avatar
Default Knock Sensor
We'll be installing a 97 H22 in a 92 Prelude SI, the H22 did not come with a knock sensor and the ECU we'll be using is a Stock JDM P13, my question is, Is there a way to Bypass or Manipulate the Knock Sensor so the CEL does not come on besides chipping the ecu? Kinda like manipulating the CKF sensor or the O2 sensor? Thanks Guys
Old Aug 17, 2006 | 03:13 AM
syntax.'s Avatar
Default Re: Knock Sensor (jdm00civicex)
Carefully remove the knock sensor from the h23a1 that you are swapping out of the 92 Si and install it in the 97 h22a4 block. It will screw right in, the wire will already be there, and the P13 will be happy happy.
Thats your easiest solution.
Old Aug 17, 2006 | 09:02 PM
Default Re: Knock Sensor (syntax.)
haha sweet, so the H23 does have knock sensor???? ooo man you took a berdon oof my shoulders...good bless you..........
Old Aug 17, 2006 | 09:36 PM
So by looking at these 2 pics from the 97 H22A4, where does the knock sensor go?
Old Aug 17, 2006 | 09:39 PM
98vtec's Avatar
moderator emeritus
Default Re: (jdm00civicex)
the one on that block is broken. Its right above the oil filter, just to the right of the vacuum box
Old Aug 17, 2006 | 09:42 PM
i thought that was it but wasnt too sure, i took that off, and it leads a tine tunnel right into the block, kinda like for crank ventilation or for coolant flow....so i guess i was right huh??
Old Aug 17, 2006 | 09:45 PM
another question is, do i also need to use the Crank sensor that goes on top of the oil pump? will the ecu throw a code if we dont use it, or do i need to go ahead and installed it, and is therea Crank sensor on the H23?
Old Aug 17, 2006 | 09:50 PM
98vtec's Avatar
moderator emeritus
are you using the h22 engine harness or h23 harness?
the crank sensor must be plugged in. That plug/sensor tells the distributor when to fire the spark plugs so its an essential part.
Old Aug 17, 2006 | 10:11 PM
we'll be using the stock h23 harness, just going to add 3 wires for vtec....does the h23 harness have the plug for the TDC sensor??
Old Aug 17, 2006 | 11:17 PM
Bumpo!
SuperBowser707
Dec 4, 2012 07:49 AM
97blacklude
Jan 31, 2009 09:56 AM
f22btwincam
Oct 15, 2002 11:26 AM
bmm89
Aug 10, 2002 07:09 PM
