what size is the oil drain plug washer and is it a regular metal crush washer or a rubber one?
I haven't had a washer on the oil drain plug for 100k miles and have forgotten what it used to look like
most hood white kid
Re: what size is the oil drain plug washer and is it a regular metal crush washer or a rubber one? (
the bolt is a 17mm, and I think the washer is regular metal washer.
if you buy an oil filter from Honda it usually comes with a crush washer
most hood white kid
Re: (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 »</TD></TR><TR><TD CLASS="quote">I never had a washer on my oil drain plug, and it never leaked. Now I got one of those magnetic drain plugs </TD></TR></TABLE>
whats the point of the magnetic drain plug?
Re: (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 »</TD></TR><TR><TD CLASS="quote">
whats the point of the magnetic drain plug?</TD></TR></TABLE>
picks up any little metal pieces that may be floating around in your motor...Besides they were only $20 a pair for the tranny and oil plugs from Marcucci Motor Sports
http://www.marcuccimotorsports.com
the washer is aluminum, should be changed every oil change as well, that way you dont overtorque your oil drain plug.
to comment on magnetic drain plugs....i suppose they could be worht somehting but i recently had some lower end problems and a magnet did not pick up anything, after all teh bearing material that wsa wearing is not magnetic. When I blew a tranny teh magnet that is already in there worked great too.
