Knock Sensor causing a problem?
Old Aug 18, 2006 | 07:28 PM
showlude93's Avatar
Default Knock Sensor causing a problem?
i have a 93' Si H23, and it is throwing a bad knock sensor code. the car is also spuddering occasionally on start ups. typically after i crank it up its fine but, when i turn it off to get gas or something is when it will sputter. and it doesn't do it all the time either. i replaced the fuel pump,strainer,filter but that didn't solve it. so the question is, could the bad sensor cause this? And if not whats left to fix?
f22b2
Aug 18, 2017 10:40 AM
DrZFiNeSt
Oct 5, 2007 04:10 AM
Blind762
May 1, 2006 02:39 AM
rocket256
Jul 12, 2004 11:45 AM
memphiss13
Jul 1, 2002 04:05 PM
