Changing Power Steering Pump
Old Aug 21, 2006 | 02:17 AM
ACLh22's Avatar
Default Changing Power Steering Pump
I have an h22, and my powersteering pump cracked. Bought another PS pump, but can't find it anywhere on here to replace it. Is it hardto change? Is it plug and play? how long should it take? better to take it to a mechanic? any info would help. TIA
Old Aug 21, 2006 | 03:45 AM
prelude_h22vtec's Avatar
plug and play, clean up the mess, add more fluid and you're good. if you know how to take off the belt, its the easiest thing you could ever do.
Old Aug 21, 2006 | 04:11 AM
mgags7's Avatar
yeah not a tough job, just make sure to bleed all the air out of the system when youre done as follows, jack the car up just enough to get the wheels off the ground and start the motor, then turn the steering wheel from lock to lock slowly a few times, then jerk it a bit, all youe trying to do is free air bubbles from the lines and inside the pump, just make sure to keep the ps reservoir full
Old Aug 22, 2006 | 12:01 AM
ACLh22's Avatar
Default Re: (prelude_h22vtec)
what belt are we talking about? and what steps would i need to do... i.e. what tools, and stuff. thanks
Old Aug 22, 2006 | 05:16 AM
mgags7's Avatar
dude you dont need to be working on a car if you cant figure out what belt you need to take off in order to change the power steering pump
why dont you pop your hood and figure this out yourself, or better yet, buy a repair manual for an h22 prelude and use that.....
my gosh the rookies these days.....
Old Aug 22, 2006 | 07:03 AM
darkspector2.0's Avatar
I know on my replacement PS pump you had to swap the pulley over.
good luck with that...
buy a manual
stevenenglund
Mar 27, 2014 05:11 AM
htwitr01
Nov 2, 2010 08:56 PM
woodzy10ec
Dec 2, 2005 11:07 AM
MiKeAhOwSkI
11
Jul 29, 2004 07:21 AM
done
May 12, 2002 11:45 AM
