Passenger Door problem
Old Aug 22, 2006 | 05:44 PM
H22a T13's Avatar
Default Passenger Door problem
Well my passenger door wont open from outside or inside. Also the window only goes %80 the way down now. Just wondering if this has happened to anyone else and if you guys have any ideas.
Old Aug 22, 2006 | 05:51 PM
AfricanBush's Avatar
Default Re: Passenger Door problem (H22a T13)
i had the same problem when the rods that connect the handle to the lock wasnt properly attached. when i took the door panel off and fixed the broken connectors it opened up from the inside and outside
Old Aug 22, 2006 | 06:29 PM
H22a T13's Avatar
Default Re: Passenger Door problem (AfricanBush)
Well dont you need to open the door to take off the pannel
Old Aug 22, 2006 | 06:55 PM
M2B4's Avatar
my window has a hard time rolling down it gets stuck and moves down like 1cm at a time then when it gets bout 70% down it works fine. odd didnt mean to thread jack but thats my problem kinda like yours
Old Aug 23, 2006 | 05:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a T13 &raquo;</TD></TR><TR><TD CLASS="quote">Well dont you need to open the door to take off the pannel</TD></TR></TABLE>
would a hanger work for u to get the door open. i would put the window down and slide in a hanger and see if u can pop the lock. it should work for u.
Old Aug 23, 2006 | 06:01 AM
bluedlude's Avatar
yeah, i had the same problem and it sucks. a coat hanger wont help you, the locking mechanism is too hidden to get at it. i would try putting your key in the door and giggling the key and the handle and pulling lightly at the same time. that was the only way i could get my door open. i had a rusted hinge on the locking mechanism that wouldnt let the linkages move. if you inside door handle doesnt move like it should you most likely have the same problem. let me know.
Old Aug 24, 2006 | 06:50 AM
H22a T13's Avatar
Default Re: Passenger Door problem (bluedlude)
Yeah the handle doesnt have any resistance to it. But this key thing doesnt work either. Do i have to take this to the dealership or is there another way. I was thinking a slim jim or w.e. that car theif tool is would work well. Any other ideas?
Old Aug 24, 2006 | 05:32 PM
H22a T13's Avatar
i need help
Old Aug 24, 2006 | 06:33 PM
Rocket Man's Avatar
Dissassemble the door panel the best u can. that is about the only way you are going to get it open is dissassembling the door panel the best you can and using some kind of tool or find the disconnected rods and work them till the door is open..
Old Aug 25, 2006 | 07:56 AM
prelude_h22vtec's Avatar
my door does the 10% at a time somedays. i'll hit the button and it will move just a little. i end up having to hit the down button 10 times to get the window down all the way.
Old Aug 31, 2006 | 01:11 PM
SeWpErMaYne's Avatar
This is one of those situations that you just take it in to a dealership that has dealt with the problem. Sometimes it takes them just a quick second and they might not even charge you.
Old Aug 31, 2006 | 01:29 PM
92nb's Avatar
Default Re: (prelude_h22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22a T13 &raquo;</TD></TR><TR><TD CLASS="quote">Well my passenger door wont open from outside or inside. Also the window only goes %80 the way down now. Just wondering if this has happened to anyone else and if you guys have any ideas.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">my door does the 10% at a time somedays. i'll hit the button and it will move just a little. i end up having to hit the down button 10 times to get the window down all the way.</TD></TR></TABLE>
It's the tracking mechanism inside the jam. They tend to rust out and the window ends up not tracking properly getting caught. This will end up burning up your window motor over time depending on how bad it is.
Old Aug 31, 2006 | 03:40 PM
H22a T13's Avatar
Default Re: (92nb)
Yeah i went to get the parts at the dealership but they diddnt have em so i payed them to have it done. 150bux was worth it to me
Vagitarian
Mar 23, 2014 12:09 PM
rayaman2
Mar 16, 2011 10:15 AM
alacard
16
Jan 25, 2007 09:55 AM
danslee
Jun 30, 2004 03:42 PM
