Intermittent VTEC
Old Feb 8, 2008 | 10:27 AM
Tyrant_007's Avatar
Default Intermittent VTEC
I'm having some trouble with VTEC. It's consistent, but doesn't hit in every gear.
Here's my configuration: I have an H22a4 in my 95 hatch. I've converted it to OBD1 by merging wiring harnesses and using the IM, ECU, etc. from an H22a1 swap. The car runs like a top. The only CEL is the EGR (or lack there-of).
The problem: When I take off in first, the VTEC kicks in. When I shift to 2nd, the VTEC never kicks in. Third, fourth, and fifth gear VTEC kicks in. Now if I take off in 2nd, VTEC will kick in through all gears including 2nd gear.
Has anyone evere experience a problem similar to this? Got any troubleshooting tips that I can test out? I searched for 'VTEC' and didn't see anything close to my problem. Any knowledgeable feedback is appreciated.
Thanks,
Matt
Old Feb 8, 2008 | 10:34 AM
98vtec's Avatar
moderator emeritus
Default Re: Intermittent VTEC (Tyrant_007)
make sure you oil is topped off
make sure the vtec solenoid screen is clean
make sure you have enough gas.
https://honda-tech.com/zerothread?id=830163
elpez
Feb 5, 2010 05:41 AM
Lightsped
26
Jan 8, 2009 02:09 PM
em1_fox
Oct 11, 2007 06:27 PM
TheAccordGuy
May 23, 2006 04:41 PM
goforbroke
Feb 24, 2003 04:47 PM
