misfire......
Old Feb 9, 2008 | 03:30 PM
H22Honda98's Avatar
Default misfire......
i used an obd2 ecu reader and foudn out that i have a misfire on cylinder 1. its running like crap. i checked the plugs and wires, and the injectors & clips look fine. what else could cause a misfire? thanks in advance guys..
-Brandon
Old Feb 9, 2008 | 09:29 PM
H22Honda98's Avatar
Default Re: misfire...... (H22Honda98)
bump........anyone have any ideas?
Old Feb 10, 2008 | 03:14 AM
Acidcrakker's Avatar
Cap and Rotor. The origin of the spark.
Old Feb 11, 2008 | 12:21 PM
importz_'s Avatar
Check out the plugs if they have any oil on them. I had the same problem and changed out the oil seals that are attached to the valve cover. Then have someone reset the car. Disconnecting the battery will not fully reset the car.
Hope this helps.
Old Feb 11, 2008 | 12:37 PM
H22Honda98's Avatar
ha yea i took it to the acura shop today instead, turns out to be a much bigger problem. hello new engine.
ekjdm89
10
Jul 7, 2011 01:55 PM
BlackCivicEX
Jan 30, 2011 08:30 PM
DieMaster
20
Sep 12, 2005 11:41 PM
D16Z6racing
Jun 15, 2005 06:50 PM
7NeverDies
Aug 29, 2004 08:57 PM
