limp mode and code 21
Old Feb 14, 2008 | 11:46 AM
Colby71's Avatar
Default limp mode and code 21
ok got all my CEL's cleared up then went out to try vtec. revlimiter at like 7000 and felt like no vtec. is this limp mode. running an h22a with a p13 usdm ecu. oh yea after rev limiter the 21 vtec thing (that would explain vtec not working).
Old Feb 14, 2008 | 12:34 PM
preludebeast94's Avatar
Default Re: limp mode and code 21 (Colby71)
No vtec, check engine light, rev limiter at 7000rpm yup thats h22 limp mode. A few things to check, oil pan see if it has a dent in it. Happend to me I wasnt getting good oil presure blocking the pick up. Also happend once because I was running a VAFC and somtimes it would throw it into limp mode. Fun stuff good luck
Old Feb 14, 2008 | 06:42 PM
Colby71's Avatar
Default Re: limp mode and code 21 (preludebeast94)
Yea I do have a big dent. I have some other things I am going to try befor the oil pan. rightnow i dont even have pins holding the wires in they are just kinda cramed in the femail spot where the ecu plugs in.
Old Feb 15, 2008 | 08:19 AM
Wow ya that could be, and the oil pan is a bitch to take off. I think it took me like 2 hours.
Old Feb 15, 2008 | 10:49 AM
Colby71's Avatar
I am lucky enough to have a lift to use. I just had the oil pan off befor I put the motor in. I hit the dents out some but prob could still use more.
Old Feb 23, 2008 | 05:26 AM
Colby71's Avatar
when you did not have oil presure what vtec code did you throw?
jasonboyce03
Oct 15, 2011 03:20 AM
951dc5
Mar 27, 2007 11:20 AM
wetnaps
Oct 2, 2005 01:32 PM
da9driver
24
Aug 25, 2005 01:00 PM
vtecplaya18
Jul 15, 2004 08:59 AM
